EE2.13: conditionals not working in exp:comment entries
June 22, 2011 1:41am
  • #1 / Jun 22, 2011 1:41am
    dsgreen
    I’m using 2.1.3 and experiencing variations of this bug. I was trying to use:
    {if avatar_url != ""}
    which did not work. But this works:
    {if avatar}
    No problem there, aside from the time wasted trying to solve the problem. A simple conditional should evaluate as expected.
    But, I’d like to apply a class based on the member group ID in the comments area. As in:
    {if member_group_id == 6}class="admin"{/if}
    This does not work, but testing for author_id does work. As in:
    {if author_id == 2}class="admin"{/if}
    Are there any updates on this bug?
    Edit: Adding a link to the original thread so this is in context.
    http://ellislab.com/forums/viewthread/174960/
  • #2 / Jun 22, 2011 1:03pm
    Kyle Cotter
    Hi Doug,
    Could you try using “member_group” instead of “member_group_id”?
    Check out Conditional Global Variables - Member Groups for more details.
    Hope you get this sorted out!
    Thanks.
  • #3 / Jun 22, 2011 1:18pm
    dsgreen
    Hi Kyle,
    Thanks for the suggestion. I just tried this, but all the commenters seem to have the same member group. When I output {member_group}, I get a “1” for everybody. When I output {member_goup_id}, I get the group ID I’m expecting for the members in a particular group. In this case, it’s an ID of “6”. The people that are not registered and just post a comment don’t have a group ID.
    So the member group ID would allow me to apply a class to comments from a specific group. The {member_group} doesn’t seem like it would work unfortunately.
    Doug
  • #4 / Jun 22, 2011 3:53pm
    dsgreen
    Well, testing for {group_id} works. I’m not sure why that works, and the others don’t. Don’t know if that is a bug or not.
    This seems to work for me:
    {exp:comment:entries channel="channel_1" paginate="bottom"}
          <div class="comment{if group_id == 6} author{/if}">
          etc…
    {/exp:comment:entries}
  • #5 / Jun 23, 2011 5:50pm
    Hi, dsgreen -
    What version are you in?  Working with EE 2.2.0, I put this code in a totally blank template:
    {exp:channel:entries channel="test" limit="10"}
    <h2><a href="http://{title_permalink=test/index}">{title}</a></h2>
    <p>{test}<br />
    {/exp:channel:entries}<br />
    {exp:comment:entries channel="test" sort="asc" limit="20"}<br />
    member_group_id: {member_group_id}</p>
    <p>{comment}<br />
    By {name} on {comment_date format="%Y %m %d"}<br />
    and on the front-end parsing, I did in fact get:
    member_group_id: 1
    so it appears to be working in EE 2.2.
  • #6 / Jun 23, 2011 6:04pm
    dsgreen
    Hi Lisa, I’m using 2.1.3.
    Doug
