Hello Everyone,
I just upgraded to EE 2.2 (from 2.1.3) and everything went smoothly. However, when I go to the CP, I get the following PHP error:
Severity: Warning
Message: date_default_timezone_get(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead
Filename: libraries/Core.php
Line Number: 227Has anyone encountered this error before? How to fix it?
Thank you in advance for your help.
Mario
