Control Panel inaccessible after update to 2.2
June 22, 2011 4:04pm
  • #1 / Jun 22, 2011 4:04pm
    mfraase
    After updating to 2.2 from the last stable build release, my Control Panel is inaccessible.
    WHAT I DID:
    Accessed http://www.sitename.com/admin.php
    WHAT HAPPENED:
    The Control Panel home page appears as expected, with the following error:
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined index: zero_tolerance
    Filename: low_nospam/ext.low_nospam.php
    Line Number: 244
    None of the AJAX top menu controls (Content, Design, Add-Ons, Members, Admin, Tools) work. The code appears to be there when I view source, but it’s not executing.
    WHAT I EXPECTED:
    Not to have a problem with low_nospam.
    My Control Panel to work properly.
  • #2 / Jun 22, 2011 5:39pm
    Brandon Jones
    mfraase,
    Can you temporarily disable extensions and make sure the control panel works normally in that case?
  • #3 / Jun 22, 2011 9:09pm
    mfraase
    Disabling extensions in the config.php file is the first thing I tried. No change.
  • #4 / Jun 23, 2011 4:29pm
    mfraase
    I did some dinking around and ended up re-downloading and re-installing 2.2. The AJAX bits in the Control Panel now appear to work (in non-AJAX form) in Firefox 5 and Chrome 13.0.782.32 but *not* Safari 5.0.5.
    Please fix this.
  • #5 / Jun 23, 2011 5:02pm
    Brandon Jones
    Hi Michael,
    By AJAX bits, what in particular are you referring to? The dropdown menus? Have you completely cleared Safari’s cache? Glad you’re making progress, just want to try to pinpoint this further.
  • #6 / Jun 23, 2011 5:10pm
    mfraase
    Yes, by AJAX bits, I mean the drop-down menus and the pop-up accessories.
    Yes, I’ve cleared all the caches, everywhere.
    Here’s another interesting data point: In Safari, when I go in via the old administration URL <http://www.sitename.com/<system_folder>> the AJAX bits work. When I go in via the new admin.php <http://www.sitename.com/admin.php> the AJAX bits don’t work (in Safari).
  • #7 / Jun 23, 2011 5:53pm
    Brandon Jones
    Man, I really cannot replicate this with Safari. Have you renamed your system folder, and if so, have you made the appropriate changes to admin.php?
    See this documentation page:
    http://ellislab.com/expressionengine/user-guide/installation/best_practices.html
  • #8 / Jun 23, 2011 6:14pm
    mfraase
    Yes, my system folder name has been changed and yes, I’ve made the appropriate changes to admin.php.
  • #9 / Jun 23, 2011 6:52pm
    mfraase
    Well, this is weird. After updating to Mac OS X 10.6.8 and a restart, the AJAX problem in Safari is resolved and the Control Panel is working as expected.
  • #10 / Jun 25, 2011 5:41pm
    Hi, mfraase -
    This very much sounds like an issue with some caching somewhere along the pipe.  I am sorry you ran into this, but I"m glad that it has cleared up.  Before I close this, I just want to ensure that it has remained in working order?
    Thank you.
  • #11 / Jun 25, 2011 6:32pm
    mfraase
    Yes, this can be closed.
  • #12 / Jun 25, 2011 6:49pm
    Thanks Michael.  If anything else comes up, please start a new thread, and have an awesome weekend.
