Hi everyone,
On a couple of sites I have done, I ended up having to create two or more of the same embedded template, with differences in the EE Channel tag, as a work-around to the EE parse order. I have used conditional statements to select which template embed to use in a situation.
In pursuit of DRY, are there any methods or tricks that you have found to alleviate some of this?
Thanks for the help!
Brian
