Configuring .htaccess
June 20, 2011 8:45am
  • #1 / Jun 20, 2011 8:45am
    kscot
    I’m looking for some help in writing an .htaccess file. In addition to removing “index.php” from the URL on the front-end, for SEO purposes I’d also like to:
    1. Remove “www” so all pages are served as “http://mydomain.com”
    2. Remove trailing slashes
    The following code seems to work OK for me:
    RewriteEngine on
    RewriteBase /
    RewriteCond %{HTTPS} !=on
    RewriteCond %{HTTP_HOST} ^www\.(.+)$ [NC]
    RewriteRule ^(.*)$ http://%1/$1 [R=301,L]
    RewriteCond %{REQUEST_URI} ^(.+)/$
    RewriteRule ^(.*)/$ /$1 [L,R=301]
    RewriteCond $1 !^(images|system|favicon\.ico|robots\.txt|sitemap\.xml|index\.php|index\.htm) [NC]
    However, I can’t access the control panel without including “index.php” in the URL, and links to thumbnail images in the control panel aren’t working. If anyone has a better, more efficient way of writing the .htaccess file to accomplish the above-stated goals I’d appreciate any suggestions.
  • #2 / Jun 20, 2011 11:45am
    Kevin Thompson’s Blog has an excellent post on this topic.  We use it, along with a few other tweaks, on all of our EE sites.
    # Redirect index.php Requests
    RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
    RewriteCond %{THE_REQUEST} !/your-ee-system-dir-goes-here/.*
    RewriteRule (.*?)index\.php/*(.*) /$1$2 [R=301,L]
    # Standard ExpressionEngine Rewrite
    RewriteCond $1 !\.(css|js|gif|jpe?g|png) [NC]
  • #3 / Jun 20, 2011 4:58pm
    Thanks for the assist, Nick!
    kscot - will that .htaccess work for you?
  • #4 / Jun 22, 2011 6:24pm
    kscot
    Nick,
    That wasn’t exactly what I was looking for but a good head’s up nonetheless. Had a gander at the post you referred to and have added that bit to my default .htaccess file.
    My original problem was I kept getting an error when I would attempt to navigate to the control panel when I tried to strip the trailing slash from the URL. I noticed that I don’t have any trouble when I instead always add trailing slashes. So that’s what I’ve decided to do. Here’s what my default .htaccess for EE installs now looks like:
    <IfModule mod_rewrite.c>
    # Enable Rewrite Engine
    RewriteEngine On
    RewriteBase /
    # Add trailing slash to all urls
    RewriteRule ^(.+)/$  /$1 [R=301,L]
    # Remove www from url
    RewriteCond %{THE_REQUEST} !/system/.*
    </IfModule>
    My main motivation is for removing “www” and always adding the trailing slash is SEO.
  • #5 / Jun 23, 2011 2:52pm
    Glad that .htaccess works for you. If anything else comes up, please do let us know in a new thread..
