A PHP ERROR WAS ENCOUNTERED
Severity: Warning
Message: ob_start() [ref.outcontrol]: output handler 'ob_gzhandler' cannot be used after 'URL-Rewriter'
Filename: core/Output.php
Line Number: 264Please advice!
June 18, 2011 9:06pm
Subscribe [3]#1 / Jun 18, 2011 9:06pm
Severity: Warning
#2 / Jun 20, 2011 8:47am
Hi, Thomas. What were you doing when the error happened? What happens if you turn off gzipping?
#3 / Jun 20, 2011 11:39am
Sue,
it shows up occasionally without any visible pattern.
Severity: Warning
Line Number: 264gzip is an essential feature to me as it speeds up page load significantly. i won’t do without it - that’s why i need to get rid of the error.
thanks for your help!
#4 / Jun 20, 2011 4:19pm
Hi Thomas,
Have you contacted your host regarding this error? A Google search indicates that this may be related to running PHP via CGI, and isn’t ExpressionEngine-specific.
#5 / Jun 20, 2011 5:00pm
I’ll check that and report back. Thanks, Brandon.
#6 / Jun 20, 2011 5:54pm
Thanks Thomas; we’ll be here.
#7 / Jun 22, 2011 4:20pm
Brandon,
i have switched off gzip for now. My host wants to know if mod_deflate is a viable option with EE?
#8 / Jun 23, 2011 12:27pm
Hi Thomas,
EE uses PHP’s standard output buffering commands. I’m not familiar with the specifics of your server setup but there are plenty of EE sites out there using Gzip successfully, so do give mod_deflate a try if possible.
#9 / Jun 27, 2011 8:17pm
A PHP Error was encountered
Severity: Warning
Line Number: 264Hi Brandon,
by now i have installed Brilliant Retail and it is running fine. Before that module i never had the above mentioned issue - so i am wondering if it is connected. where exactly does ‘URL-Rewriter’ come into play with EE?
btw, i get the warning even after i switch gzip off in EE.
#10 / Jun 28, 2011 8:43pm
Hi, Thomas,
We haven’t seen that error come up before; if you uninstall BR temporarily, does the error go away? If so, you may need to follow up with the Brilliant Retail folks.
Let us know!
#11 / Jun 30, 2011 11:33am
Lisa,
i’ll let you know as soon as i find out. Thanks for your support.
#12 / Jun 30, 2011 4:07pm
My pleasure, Thomas. I"ll leave this open for that follow up. Thanks!
#13 / Jun 30, 2011 4:08pm
Encantado, Lisa!
#14 / Jul 01, 2011 12:10pm
Thanks Thomas, keep us posted.
