Sure Sue,
Here is the index.php for the second website:
<?php
ExpressionEngine - by EllisLab
<a href="http://expressionengine.com/">http://expressionengine.com/</a>
Copyright (c) 2003 - 2007 EllisLab, Inc.
THIS IS COPYRIGHTED SOFTWARE
PLEASE READ THE LICENSE AGREEMENT
<a href="http://expressionengine.com/docs/license.html">http://expressionengine.com/docs/license.html</a>
File: index.php
Purpose: Triggers the main engine
// URI Type
// This variable allows you to hard-code the URI type.
// For most servers, 0 works fine.
// 0 = auto
// 1 = path_info
// 2 = query_string
$qtype = 0;
// DO NOT EDIT BELOW THIS!!!
error_reporting(0);
if (isset($_GET['URL']))
/** URL Redirect for CP and Links in Comments
$_GET['URL'] = str_replace(array("\r", "\r\n", "\n", ':',':','/','/'),
array('', '', '', ':', ':', '/', '/'),
$_GET['URL']);
if (substr($_GET['URL'], 0, 4) != "http" AND ! ereg('://', $_GET['URL']))
$_GET['URL'] = "http://".$_GET['URL'];
$_GET['URL'] = str_replace( array('"', "'", ')', '(', ';', '}', '{', 'script%', 'script&', '(', ')'),
strip_tags($_GET['URL']));
$host = ( ! isset($_SERVER['HTTP_HOST'])) ? '' : (substr($_SERVER['HTTP_HOST'],0,4) == 'www.' ? substr($_SERVER['HTTP_HOST'], 4) : $_SERVER['HTTP_HOST']);
if ( ! isset($_SERVER['HTTP_REFERER']) OR ! stristr($_SERVER['HTTP_REFERER'], $host))
// Possibly not from our site, so we give the user the option
// Of clicking the link or not
$str = "<html>\n<head>\n<title>Redirect</title>\n</head>\n<body>".
"To proceed to the URL you have requested, click the link below:".
"<a href="http://.$_GET">".$_GET['URL']."</a>\n</body>\n</html>";
else
$str = "<html>\n<head>\n<title>Redirect</title>\n".
'<meta http-equiv="refresh" content="0; URL='.$_GET['URL'].'">'.
"\n</head>\n<body>\n</body>\n</html>";
exit($str);
$uri = '';
$pathinfo = pathinfo(__FILE__);
$ext = ( ! isset($pathinfo['extension'])) ? '.php' : '.'.$pathinfo['extension'];
$self = ( ! isset($pathinfo['basename'])) ? 'index'.$ext : $pathinfo['basename'];
$path_info = (isset($_SERVER['PATH_INFO'])) ? $_SERVER['PATH_INFO'] : @getenv('PATH_INFO');
$query_str = (isset($_SERVER['QUERY_STRING'])) ? $_SERVER['QUERY_STRING'] : @getenv('QUERY_STRING');
switch ($qtype)
case 0 : $uri = ($path_info != '' AND $path_info != "/".$self) ? $path_info : $query_str;
break;
case 1 : $uri = $path_info;
break;
case 2 : $uri = $query_str;
break;
unset($system_path);
unset($config_file);
unset($path_info);
unset($query_str);
unset($qstr);
require 'path'.$ext;
if ((isset($template_group) AND isset($template)) && $uri != '' && $uri != '/')
$template_group = '';
$template = '';
if ( ! isset($system_path))
if (file_exists('install'.$ext))
header("location: install".$ext);
exit;
else
exit("The system does not appear to be installed. Click <a href="http://install.php">here</a> to install it.");
if ( ! ereg("/$", $system_path)) $system_path .= '/';
if ( ! @include($system_path.'core/core.system'.$ext))
exit("The system path does not appear to be set correctly. Please open your path.php file and correct the path.");
I am not using an admin.php mask. The admin for the second site is under the first site’s domain and control panel.
