After updating to version 2.1.3, I can’t find the “logs” directory. Does it means it doesn’t use logs anymore? May be I should create it by hand? Where?
June 14, 2011 8:54am
Subscribe [2]#1 / Jun 14, 2011 8:54am
#2 / Jun 15, 2011 5:33am
Hi Ñuño,
You can enable logs by opening up system/expressionengine/config/config.php and editing this section
| Error Logging Threshold
| If you have enabled error logging, you can set an error threshold to
| determine what gets logged. Threshold options are:
| 0 = Disables logging, Error logging TURNED OFF
| 1 = Error Messages (including PHP errors)
| 2 = Debug Messages
| 3 = Informational Messages
| 4 = All Messages
| For a live site you'll usually only enable Errors (1) to be logged otherwise
| your log files will fill up very fast.
$config['log_threshold'] = 0;
| Error Logging Directory Path
| Leave this BLANK unless you would like to set something other than the default
| system/logs/ folder. Use a full server path with trailing slash.
$config['log_path'] = '';Does that help?
#3 / Jun 15, 2011 6:45am
Does that help?
Yes it does. I didn’t revised the configuration file (my fault :oops:).
The problem is that the directory doesn’t exist and I didn’t knew where it should be created. Our config file includes the full “log_path” so I can create it and see if it works.
Thanks.
#4 / Jun 15, 2011 6:49am
Ñuño,
No problems. Also if you leave log_path blank it will create the system/logs folder for you.
Are you happy with me to close this one out or do you wish to further test it?
#5 / Jun 15, 2011 7:14am
I think you can close it. Thank you. 😊
#6 / Jun 15, 2011 7:15am
No problems. Feel free to start a new thread if you have any more questions
