Show Entry ONLY if it has a comment from the current user?
June 13, 2011 8:42pm
  • #1 / Jun 13, 2011 8:42pm
    pcm
    Is this possible? I’ve tried a lot of different things. I can get obviously show comments just from the current user, but I can’t get the initial results to filter in a way where an entry isn’t showed at all if there’s not a comment from the user.
    Anyone point me in the right direction? For the sake of an example, I’ll put what I have below, but I obviously need another layer at the exp:channel:entries level to filter the output before it even gets to showing the actual comments.
    {exp:channel:entries channel="channel1" disable="trackbacks|member_data|pagination" show_future_entries="yes" orderby="title" sort="asc" limit="8"}
                        <h2>{title}</h2>
    <p>                    {exp:comment:entries entry_id="{entry_id}" comment_id="{comment_id}" sort="desc" orderby="date" limit="10" dynamic="yes" }<br />
                            <br />
                                {if logged_in_member_id == author_id}<br />
                                    {comment}<br />
                                {/if}<br />
                            <br />
                        {/exp:comment:entries}<br />
    Moved to Community Help forum by Moderator
  • #2 / Jun 14, 2011 3:11pm
    pcm,
    I wouldn’t suggest nesting your Comment Entries tag inside the Channel Entries tag like this. I would go the way of a Query to wrap it in to check if the logged in user has a comment for that entry and show then.
    I can move this thread to the Community Help forum for you where other members may be able to help you with that specific query?
  • #3 / Jun 14, 2011 3:39pm
    pcm
    That would be great. Thank you.
  • #4 / Jun 15, 2011 1:02pm
    Moving per request..
