Hello people,
I need a bit of help with my member list.
I was provided with a list of 300+ members that needs to be imported into EE. Every member has a bunch of info, so i’ll create custom fields.
That’s where the fun starts. The Excel file I was given lists every member with multiple addresses as separate rows, so I’ve got duplicate members, and emails, which messes up the import process.
So plan B would be to reformat the Excel file, so that each row has address1, zipcode1, address2, zipcode2…
It sure makes a lot of sense from a database design point of view, but when I call my custom fields in the search dropdown included with the member list template, I end up with Zip Code 1 and Zip Code 2 as search options, which is obvisouly confusing.
I need to be able to search multiple database fields for zip codes at the same time.
So… i’m stuck. Any suggestion would be greatly appreciated.
Cheers - Nicolas.
