EE Version 2.1.3
Build 20101220
Not sure what to make of this one: On my client’s computer, when the status of an entry is set to closed, the entry will show as closed in the CP, but will still be active on the website. When I login from my computer, the CP shows the entry as open (meanwhile it’s still showing as closed on the client’s computer). Both of our member accounts are SuperAdmin. When I set status to closed on my computer, the change takes effect. Status is reflected as closed in the CP and the entry is removed from the front end.
We have tried resetting browsers and using different browsers on the client’s machine, but the issue persists and I am perplexed. Any thoughts will be greatly appreciated.
Thank you,
Will
