Does the freelancer licence have all the modules to build a blog that has commenting?
I know it doesn’t include the Members module and the SAEF module.
June 04, 2011 7:09am
Subscribe [3]#1 / Jun 04, 2011 7:09am
#2 / Jun 04, 2011 12:23pm
opel,
Check out the pricing table on this page: http://expressionengine.com/overview/pricing
It shows what features are with what products.
#3 / Jun 04, 2011 12:47pm
Yeah I’ve read that but what it doesn’t tell you is that the SAEF isn’t included that some tuts I saw for blogs said that you need this for commenting. I’m double checking there is nothing else not on that list.
#4 / Jun 04, 2011 2:23pm
You can use the SAEF with Freelancer (SAEF is deprecated, please consider using SafeCracker instead. Also works on Freelancer). And you can use commenting on Freelancer as well. =) What you can’t do is have front-end member profile viewing and editing on Freelancer, or forums, etc.
#5 / Jun 04, 2011 2:51pm
great thanks
#6 / Jun 05, 2011 6:19pm
Glad Lisa was able to help. Don’t hesitate to post as as needed.
