PHP error: "not a valid Directory resource"
May 31, 2011 1:07pm
  • #1 / May 31, 2011 1:07pm
    imaginesurf
    I have the EE system (renamed to something else) installed above root. When I run a simple PHP script from the homepage index, which opens an images directory under normal root, it gives me a “not a valid Directory resource” error.
    I don’t want to post the literal server path here, but it looks something like this:
    /home/accountid/domains/domainname.com/html/photos/
    I can access the http://www.domainname.com/photos directory from a browser, but EE seems not able to understand the location when I use the absolute path on the server (as I understand must be used).
    Any help?
  • #2 / Jun 01, 2011 5:35am
    Hi imaginesurf,
    can you elaborate a bit more on your PHP script. How do you mean ‘open’ an images directory?
    I don’t have the full picture here yet but you can try changing the uri_protocol in your config.php to PATH_INFO from AUTO to see if that helps
    $config['uri_protocol']    = 'PATH_INFO';
  • #3 / Jun 01, 2011 8:02am
    imaginesurf
    I ended up recommending to my client that they request a refund. This was just one question among many others that took too long to get a response to and thus made development impractical.
    Evidently I had unrealistic expectations of EE support. Thanks anyway.
    Unsubscribing from this thread.
  • #4 / Jun 01, 2011 3:40pm
    Brandon Jones
    imaginesurf, (in case you are still reading this 😉) please note our Support Policy. Going ahead and closing this one out.
