I have all my new sites on EE2.1.3, but my old dog was never updated due to the sheer size and my fear of stewing things up—but I’m ready to move it over to EEv2 as well.
I understand the conversion process will convert my EE1.x templates to EE2.x templates, but I’m not sure how to go about making them “flat files.” I enabled the export to file option as direct din the User Guide, and all the various templates were saved as PHP files. ??? I ran the update wizard, and I got an error stating the templates weren’t readable text files.
So…
1. I went back to my templates and used the Export Templates option, and all the templates were saved as TXT files, so I assume that’s what I need. Is this correct?
2. The directions say to save the templates to “system/expressionengine/templates/<site_short_name>,” but it seems that you specify a short name when you’re using the Multiple Site Manager? What’s my site_short_name supposed to be?
2a. Another part in the directions says to move them into “system/expressionengine/templates/”—no “short name.” Which is correct?
3. The exported templates from item 1 are organized like so: “search_tmpl,” “site_tmpl,” and so forth. Do you put those directories into the directory from item 2? Do I keep the folder names as exported?
