Running 2.1.3 on a local MAMP install and getting a strange issue. All is installed fine, and the login to the DB is fine.
We can create template and templates groups, but can’t add anything to the content of templates. Submitting sends the info, but nothing is saved, although the revision time is saved.
We checked the permissions for the user, and even used root/root which should have full permissions. We checked index.php/config.php/database.php and they are all set to the correct paths etc.
Anyone come across this at all? Any pointers in the right direction?
