url_title helper method doesn't honor global channel preference
May 16, 2011 2:49pm
  • #1 / May 16, 2011 2:49pm
    Brian M.
    In the control panel,  I have used the setting here:
    admin->channel admin->global preferences->Word Separator for URL Titles
    to set the system to use the _ (underscore) when generating url_titles.
    If I put this code anywhere in a template or module/extension, it uses - (hypen) to create the url_title, ignoring the preference set in the CP.
    $this->EE->load->helper('url');
    echo url_title("hello chicago!");
    This generates:
    hello-chicago
    I’m assuming that’s a bug?
  • #2 / May 17, 2011 2:54am
    Brain,
    No bug. When calling the helper like this you need to specify your choice
    <?php
    echo url_title("hello chicago!", '_');
    The preference in the CP is used at entry save time
  • #3 / May 17, 2011 9:37am
    Brian M.
    Oops. I’m still getting used to using EE2 - I keep forgetting to check the CodeIgnitor side of things.  Thanks!
  • #4 / May 17, 2011 11:51am
    Glad John was able to help. Don’t hesitate to post again as needed.
