Is there a way to cut down the ever growing datatable exp_throttle?
May 12, 2011 2:40pm
Subscribe [4]#1 / May 12, 2011 2:40pm
#2 / May 12, 2011 9:46pm
franxx, a quick look at the source code says this should take care of itself, clearing the database of old entries every 7 days (or soonest after 7 days when someone looks at a page).
However, the conditions for clearing to occur include;
- you must have Enable Online User Tracking set, in Admin>Security and Privacy>Tracking Preferences
AND
- you must actually have throttling turned on, via Admin>Security and Privacy>Throttling Preferences>Enable Throttling
In other words, it’s going to clear, and once a week (date/time not determined easily), only if you actually have throttling and user tracking both enabled.
That’s what the code seems to say. Also, I note there was an item on today’s 2.1.5 release document that something had been fixed in this area. On an older 2.x site where I know I’ve hit throttling because of testing, the log is nearly empty (2 items), and both the settings mentioned are on, so I think the clearing does work.
Answering on this only because I know others who would know better are busy with the release. You can try these settings, and see if your database shrinks properly in a week or so, for now.
Good fortune on it, and regards,
Clive
#3 / May 13, 2011 6:09am
Thanks Clive. Can you try those settings and let us know if the throttling table clears for you in time.
I’ll leave this thread open in the meantime.
#4 / May 16, 2011 7:59am
Thank you Clive.
Admin>Security and Privacy>Tracking Preferences enabled
plus
did the job. exp_throttle has now only 400kb.
#5 / May 16, 2011 10:01am
Excellent! Feel free to start a new thread if you have any more questions.
