I tried to activate a pending member, and had the email notification box checked, but when I submitted the form I got an error like the one below and now get this error on one of my templates:
ion clean_email($email) { if ( ! is_array($email)) { if (preg_match('/\<(.*)\>/', $email, $match)) return $match['1']; else return $email; } $clean_email = array(); for ($i=0; $i < count($email); $i++) { if (preg_match( '/\<(.*)\>/', $email[$i], $match)) $clean_email[] = $match['1']; else $clean_email[] = $email[$i]; } return $clean_email; } /* END */ /**————————————————————————/** Strip HTML from message body /**————————————————————————*/ // This function provides the raw message for use // in plain-text headers of HTML-formatted emails function strip_html() { $body = ($this->plaintext_body != '') ? $this->plaintext_body : $this->body; if (preg_match('@\@i', $body, $match)) { $body = $match['1']; $body = substr($body, strpos($body, ">") + 1); } $body = trim(strip_tags($body)); $body = preg_replace( ‘##’, “”, $body); $body = str_replace(”\t”, “”, $body); for ($i = 20; $i >= 3; $i—) { $n = ""; for ($x = 1; $x <= $i; $x ++) $n .= $this->newline; $body = str_replace($n, $this->newline.$this->newline, $body); } return $this->word_wrap($body, ‘76’); } /* END */ /**——————————————————- /** Word Wrap /**——————————————————-*/ function word_wrap($str, $charlim = ‘’) { // Set the character limit if ($charlim == '') { $charlim = ($this->wrapchars == "") ? "76" : $this->wrapchars; } // Reduce multiple spaces $str = preg_replace(”| +|”, ” “, $str); // Standardize newlines $str = preg_replace(”/\r\n|\r/”, “\n”, $str); // If the current word is surrounded by {unwrap} tags we’ll // strip the entire chunk and replace it with a marker. $unwrap = array(); if (preg_match_all(”|(\{unwrap\}.+?\{/unwrap\})|s”, $str, $matches)) { for ($i = 0; $i < count($matches['0']); $i++) { $unwrap[] = $matches['1'][$i]; $str = str_replace($matches['1'][$i], "{{unwrapped".$i."}}”, $str); } } // Use PHP’s native function to do the initial wordwrap. // We set the cut flag to FALSE so that any individual words that are // too long get left alone. In the next step we’ll deal with them. $str = wordwrap($str, $charlim, “\n”, FALSE); // Split the string into individual lines of text and cycle through them $output = “”; foreach (explode(”\n”, $str) as $line) { // Is the line within the allowed character count? // If so we'll join it to the output and continue if (strlen($line) <= $charlim) { $output .= $line.$this->newline; continue; } $temp = ‘’; while((strlen($line)) > $charlim) { // If the over-length word is a URL we won't wrap it if (preg_match("!\[url.+\]|://|wwww.!", $line)) { break; } // Trim the word down $temp .= substr($line, 0, $charlim-1); $line = substr($line, $charlim-1); } // If $temp contains data it means we had to split up an over-length // word into smaller chunks so we’ll add it back to our current line if ($temp != ‘’) { $output .= $temp.$this->newline.$line; } else { $output .= $line; } $output .= $this->newline; } // Put our markers back if (count($unwrap) > 0) { foreach ($unwrap as $key => $val) { $output = str_replace("{{unwrapped".$key."}}”, $val, $output); } } return $output; } /* END */ function prep_quoted_printable($str, $charlim = ‘’) { // Set the character limit // Don't allow over 76, as that will make servers and MUAs barf // all over quoted-printable data if ($charlim == '' OR $charlim > '76') { $charlim = '76'; } // Reduce multiple spaces $str = preg_replace(”| +|”, ” “, $str); // Standardize newlines $str = preg_replace(”/\r\n|\r/”, “\n”, $str); // kill nulls $str = preg_replace(’/\x00+/’, ‘’, $str); // We are intentionally wrapping so mail servers will encode characters // properly and MUAs will behave, so {unwrap} must go! $str = str_replace(array(’{unwrap}’, ‘{/unwrap}’), ‘’, $str); // Break into an array of lines $lines = preg_split(”/\n/”, $str); $escape = ‘=’; $output = ‘’; foreach ($lines as $line) { $length = strlen($line); $temp = ''; // Loop through each character in the line to add soft-wrap // characters at the end of a line " =\r\n" and add the newly // processed line(s) to the output for ($i = 0; $i < $length; $i++) { // Grab the next character $char = substr($line, $i, 1); $ascii = ord($char); // Convert spaces and tabs but only if it's the end of the line if ($i == ($length - 1)) { $char = ($ascii == '32' OR $ascii == '9') ? $escape.sprintf('s', dechex($ascii)) : $char; } // encode = signs if ($ascii == ‘61’) { $char = $escape.strtoupper(sprintf('s', dechex($ascii))); // =3D } // If we’re at the character limit, add the line to the output, // reset our temp variable, and keep on chuggin’ if ((strlen($temp) + strlen($char)) >= $charlim) { $output .= $temp.$escape.$this->crlf; $temp = ''; } // Add the character to our temporary line $temp .= $char; } // Add our completed line to the output $output .= $temp.$this->crlf; } // get rid of extra CRLF tacked onto the end $output = substr($output, 0, strlen($this->crlf) * -1); return $output; } /* END */ function prep_q_encoding($str, $from = FALSE) { global $PREFS; $str = str_replace(array(”\r”, “\n”), array(’‘, ‘’), trim($str)); // Line length must not exceed 76 characters, so we adjust for // a space, 7 extra characters =??Q??=, and the charset that we will add to each
... etc
Help?
