CP links with index.php?URL=http:// do not resolve
May 07, 2011 11:04pm
Subscribe [4]
  • #1 / May 07, 2011 11:04pm
    Simon Cox
    Hi
    When I click an entries View link I get the rewrite URL:
    http://www.mydomain.com/index.php?URL=http://www.mydomain.com/index.php?/1/article/12
    But it does not resolve - looks like there is an attempt to do this as the browser constantly refreshes in an infinate loop.
    Any ideas what may be causing this?
    I am using a .htaccess rewrite rule to remove the index.php but I have removed this in the .htaccess file to test and it didn’t make any difference.
    Running on LAMP - but have tried Force URL query strings - no difference.
    Running EE 2.1.3
    Extensions:
    Accessible Captcha
    CP Analytics Settings
    Flickr (Which I just installed and is suffering the same problem - can’t get this to work because the URL appear to be rewritten in a loop - same as View entry issue above.)
    Libraree
    Matrix
    Playa
    SafeCracker
  • #2 / May 08, 2011 1:53am
    JohanD
    This might not solve your infinite redirection issues, but the “1” in “/1/article/12” looks a little suspicious, is your template group called 1 ?
    If not, you can change the destination template group in the channel preferences, Path Settings, then Channel URL.
    BTW, If you remove the index.php using a .htaccess file, you have to remove it as well from your EE General Configuration, and from each channel’s settings.
    I hope this helps a bit…
    PS, EllisLab, could the entry url title be used for the View Entry and Live Look links, instead of the entry id? Even though we can turn on strict urls, this still causes duplicate urls…
  • #3 / May 08, 2011 12:00pm
    Simon Cox
    Thanks Johan, the 1/ is not a problem - that set of templates is named one - unusual and not best practice for SEO but in this particular case it works.
    I had already ensured the channels went to the correct url without index.php but thanks for the reminder about the General config Name of your site’s index page field - I had forgotten that one and have removed the index.php and now the View entries resolves correctly.
    Thank you.
    So thats not the problem that was causing the Flickr Extension not to work - back to the drawing board on that part.
    Can close.
  • #4 / May 09, 2011 5:41am
    Hi Simon,
    Can you rename the htaccess file to be sure please.
    So you have a live look template set up?
    Can you create a blank one and just add the basic tags and link to that in your Channel Prefs
  • #5 / May 09, 2011 8:26pm
    Simon Cox
    JH - I renamed the .htacess file but it still worked. Honestly I think its fixed…
  • #6 / May 10, 2011 1:23pm
    Hey Simon!
    Go ahead and rename .htaccess back.  Double check that this is working for you and let us know; I don’t want to prematurely close this, but I think that you’ve got the issue sorted. Just want to make sure. =)
  • #7 / May 10, 2011 3:53pm
    Simon Cox
    Honestly it is working Lisa - I really do mean it. I know its hard to believe but sometimes you have to go with you instincts and trust me on this.
    Can close.
    Really.
    You really can close this thread.
  • #8 / May 10, 2011 10:11pm
    😊 Closing per request. Feel free to start a new thread if you have any more questions.
