Is there a way to output INSERT and UPDATE sql statements for CP actions?
April 13, 2011 7:38am
Subscribe [4]
  • #1 / Apr 13, 2011 7:38am
    moonbeetle
    The output profiler if enabled shows all the SQL statements needed to render a page. Except for the session id, almost always SELECT select statements.
    Suppose you create or update a channel, a new field group, custom fields, categories, statuses…would it be possible to output or log the INSERT and UPDATE queries for these actions?
  • #2 / Apr 13, 2011 11:51am
    giusi
    I don’t know if you can output what you need withouth hacking or extending the code.
    Anyway MySQL has a Query Log you can probably access (depends on your environment and hosting). This post could prove helpful.
  • #3 / Apr 13, 2011 2:32pm
    Can I ask what you’re needing it for?
  • #4 / Apr 13, 2011 4:17pm
    moonbeetle
    Recently I had to setup a section on a few existing websites and the setup (channel, custom fields) was identical. Not a difficult job but quite some time went into configuring all the custom fields. So I was wondering if there is a way to do the same job faster.
  • #5 / Apr 13, 2011 6:05pm
    Mark Bowen
    If you are doing the exact same fields each time then take a look at MX Tool Box by the fantastic Max. Can definitely save some time when doing this sort of thing.
    Best wishes,
    Mark
  • #6 / Apr 13, 2011 6:38pm
    moonbeetle
    Mark, that module is just fantastic. Just tested it. Will say thanks to Max too.
  • #7 / Apr 14, 2011 11:40am
    Thanks for the assist, Mark.
    moonbeetle - Feel free to start a new thread if you have any more questions.
