I’ve noticed when using the AJ Penninga image replacement method (with Matrix, ImageSizer and NSM Transplant) that when a file field is left blank, Safecracker file still sends a ‘.’ through to ImageSizer and thus ImageSizr chokes looking for a file and spitting out errors about “this format or extension not found/supported.”
So basically when a page is created without an image it has all these PHP errors at the top of the page because ImageSizer is choking on it. I know there are a lot of other Addon’s involved here, but this worked fine with the EE file field and only after switching to Safecracker did this problem start happening. I’d like to see if this is reproducible before filing a bug.
EE 2.1.3, latest versions of Safecracker, Matrix, NSM Transplant, Imgasizer)
