Showing Expired and Future Events
April 06, 2011 3:35pm
  • #1 / Apr 06, 2011 3:35pm
    KAAB
    I am trying to display both expired and future entries on a sports team page so that users can see scores of past contests in addition to upcoming contests. Right now, the current setup is only showing expired contests. Changing to dynamic=“off” has had no effect.
    {exp:weblog:entries weblog="upcoming" dynamic="off" related_categories_mode="on" show_future_entries="yes" show_expired="yes" sort="asc"}
    {if upcoming-event}
         {upcoming-event}
          <tr>
             <td>{entry_date format='%D'}</td>
             <td>{entry_date format='%m/%j'}</td>
             <td>{event-opponent}</td>
             <td>{event-location}</td>
             <td>{event-time}</td>
             <td>{event-results}</td>
          </tr>
         {/upcoming-event}
         {if no_results}
         <tr class="no-sched">
            <td class="empty" rowspan="3" colspan="5">There are no scheduled events.</td>
         </tr>
    {/exp:weblog:entries}
    Thanks in advance for the help.
  • #2 / Apr 07, 2011 1:51pm
    Hi, KAAB -
    First, let’s start by simplifying the tag.  You may be hiding things unintentionally using that conditional
    Can you try this:
         {upcoming-event}
          <tr>
          </tr>
         {/upcoming-event}
         {if no_results}
         </tr>
    Also, is upcoming_event a Matrix field or something else?
    and lastly, are these all Open status?
    Thank you!
  • #3 / Apr 11, 2011 1:31pm
    KAAB
    Hi Lisa,
    Yes, upcoming-event is a Matrix field and all entries are defaulted to the “open” status.
    I have updated to the code snippet to what you provided, but am still seeing the same results:
         {upcoming-event}
          <tr>
          </tr>
         {/upcoming-event}
         {if no_results}
         </tr>
    Any additional insight would be very helpful. This seems like it should be an easy fix, but I haven’t been able to find any resources regarding this specific issue. You can see the issue on the live site by clicking on the schedule tab here: http://sheldonathletics.com/teams/spring-sports/baseball/ There are currently games scheduled out through April 16 and none of them are showing up past the last expired event.
    Thanks again in advance
  • #4 / Apr 11, 2011 8:50pm
    KAAB
    When I set the limit to 250, I was able to see everything. This will work for now, though it is less than ideal
  • #5 / Apr 12, 2011 7:41am
    KAAB,
    EE has a default limit of 100 so anything over that then you will have to manually set.
  • #6 / Apr 12, 2011 12:48pm
    KAAB
    That shouldn’t be a problem as most of these lists only contain 20-40 items at most.
  • #7 / Apr 12, 2011 8:39pm
    Brandon Jones
    Sounds good, KAAB. Glad that works!
