I’m having the same problem as the above thread with 404 errors on any URL with periods in the URI.
I tried the solution of changing the config value for url_protocol from PATH_INFO to REQUEST_URI
This fixed the 404 error on pages with any periods, but now the HOME button on my nav bar gives the error:
The URI you submitted has disallowed characters.
The URL the HOME button generates is:
http://www.stretcher.org.php5-18.dfw1-1.websitetestlink.com/stretcher_admin_sys/index.php?S=0&D=cp
If I enter:
into the address bar, it works fine.
Everything else in the CP is fine.
What do I need to fix for the HOME button to work again?
David
Moved to CodeShare Corner by Moderator
