MySQL version issue
April 05, 2011 1:12am
  • #1 / Apr 05, 2011 1:12am
    Studio Graphiko
    Hello, I installed and ran your Compatibility Wizard on my web hosting space at InterXstream.com and everything looked okay except the MySQL (v. 4.1+) support in PHP—which got red flagged. The result under the Supported column came up “No”. So I asked about the version that’s installed and I was told they are running MySQL v 5.0.91. Is this going to be a problem implementing Expression Engine?
  • #2 / Apr 05, 2011 1:56pm
    Brandon Jones
    Hi Studio Graphiko, and welcome to the forums!
    More than likely the issue is that MySQL simply isn’t enabled on your server, so contact your host to make sure it’s running. That version should be fine.
    Let us know if you have any other questions!
  • #3 / Apr 05, 2011 2:34pm
    Studio Graphiko
    Hi Brandon, thanks for the reply. Okay, that sounds fine. I’ll ask about it. Just wanted to make sure before I purchase the license.
    Regards,
    Steven
  • #4 / Apr 06, 2011 2:15pm
    Leslie Doherty
    Hi Steven, it sounds like you’re set? I’m going to close this thread. You can always open a new one if you have another question. Thank you!
