passing xhtml to embeds
April 01, 2011 9:06am
Subscribe [5]
  • #1 / Apr 01, 2011 9:06am
    _Oli
    Hello,
    I seem to be having a weird issue and after looking through the forums, I can’t find anything similar…
    I’m trying to pass values to an embed but for some reason links in my field content seem to break. I have the latest build/version of ee2 installed.
    I have stripped all html from the templates and I’m only testing the tags.
    Here are the templates:
    Main template:
    {exp:channel:entries channel="advertorial" limit="1"}
    {embed="news/inner" title="{title}" test_field="{test_field}" advertorial_article="{advertorial_article}"}
    test_field is a normal textarea field with xhtml formatting on.
    advertorial_article is a Wygwam field.
    Embeded Template:
    <h1>{embed:title}</h1>
    <h2>Wygwam field</h2>
    <p>{embed:advertorial_article}</p><h2>Default field</h2>
    <p>{embed:test_field}
    If test_field or advertorial_article contain only paragraph or headings or any simple html tags, all is fine. If I add a link to the content (simple a tag) here what the result source looks like: http://oli.gd/5fYA
    Anyone experienced this before?
  • #2 / Apr 01, 2011 9:14am
    Joobs
    have you tried turning off “automatically turning urls into links” and resaving the entry?
  • #3 / Apr 01, 2011 9:15am
    Est Digital
    Have you tried to use single quotes?
    advertorial_article=’{advertorial_article}’
  • #4 / Apr 01, 2011 9:19am
    _Oli
    Joobs - Yup first thing I did. No fix..
    Piet - Genius… That was the fix… I can’t believe it was such a simple issue.
    Thank you both for for the quick response!
    Have a good day
  • #5 / Apr 01, 2011 5:49pm
    Thanks for the assist, Joobs and Piet.
    _Oli, Feel free to start a new thread if you have any more questions.
  • #6 / Apr 02, 2011 8:52am
    webdeveloper
    I had the exact same issue here, same solution too.
    http://ellislab.com/forums/viewthread/157090/
  • #7 / Apr 05, 2011 4:41pm
    Sounds like everybody is working.. Feel free to start a new thread if you have any more questions.
