Database error 1054 after deleting a custom channel field
March 30, 2011 5:41am
  • #1 / Mar 30, 2011 5:41am
    MedPro
    Hello,
    possibly after deleting a custom channel field, i get this error:
    A Database Error Occurred
    Error Number: 1054
    Unknown column 'field_id_150' in 'field list'
    INSERT INTO ee_channel_data (entry_id, channel_id, site_id, field_id_148, field_id_120, field_id_119, field_id_132, field_id_133, field_id_150, field_id_118, field_id_109, field_id_110, field_id_111, field_id_112, field_id_114, field_id_115, field_id_116, field_id_117, field_id_121, field_id_122, field_id_123, field_id_124, field_id_125, field_id_126, field_id_127, field_id_128, field_id_129, field_id_130, field_id_131, field_id_134, field_id_135, field_id_139, field_id_140, field_id_141, field_id_142, field_id_143, field_id_144, field_id_145, field_id_146, field_id_147, field_id_149, field_id_113, field_ft_109, field_ft_110, field_ft_111, field_ft_112, field_ft_113, field_ft_114, field_ft_115, field_ft_116, field_ft_117, field_ft_118, field_ft_119, field_ft_120, field_ft_121, field_ft_122, field_ft_123, field_ft_124, field_ft_125, field_ft_126, field_ft_127, field_ft_128, field_ft_129, field_ft_130, field_ft_131, field_ft_132, field_ft_133, field_ft_134, field_ft_135, field_ft_139, field_ft_140, field_ft_141, field_ft_142, field_ft_143, field_ft_144, field_ft_145, field_ft_146, field_ft_147, field_ft_148, field_ft_149, field_id_1, field_id_2, field_id_3, field_id_4, field_id_5, field_id_6, field_id_7, field_id_8, field_id_10, field_id_11, field_id_12, field_id_13, field_id_36, field_id_37, field_id_38, field_id_39, field_id_40, field_id_42, field_id_43, field_id_44, field_id_46, field_id_47, field_id_48, field_id_51, field_id_52, field_id_54, field_id_56, field_id_57, field_id_58, field_id_59, field_id_60, field_id_61, field_id_62, field_id_63, field_id_64, field_id_65, field_id_66, field_id_67, field_id_68, field_id_69, field_id_70, field_id_71, field_id_74, field_id_75, field_id_76, field_id_77, field_id_78, field_id_79, field_id_80, field_id_81, field_id_82, field_id_83, field_id_84, field_id_85, field_id_86, field_id_87, field_id_88, field_id_89, field_id_90, field_id_91, field_id_92, field_id_93, field_id_94, field_id_95, field_id_96, field_id_97, field_id_98, field_id_99, field_id_100, field_id_101, field_id_102, field_id_103, field_id_104, field_id_105, field_id_106, field_id_107, field_id_108, field_id_136, field_id_137, field_id_138) VALUES (192, '19', '1', '9', '1,08 (s hadicí)', '245', '2,9', '5000', '', '2,5', 'T315-S', 'Výkonná a tichá pneumatická pilka', 'Pneumatická pilka T315S je obzvláště výkonná a tichá. Je možné ji používat k řezání s běžnými úpilovými listy, je ale potřeba opilovat ozubení na části, která je upnutá v držáku pilky.\n\nK dispozici je rovněž držák nástroje pro pilování, o rozměrech 4 a 6 mm.', 'Přímočaré pilky', '', '', '', 'Přípojka', '', '', '', '', '', '', '', '', 'Ano', '', '', '', '', '', '', '', '', '', '', '', '', '', '', 'https://store.ellislab.com/asset/images/avatars/pilka-t315s.jpg', 'none', 'none', 'xhtml', 'none', 'xhtml', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', 'none', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '')
    Filename: libraries/api/Api_channel_entries.php
    Line Number: 1808
    What happened exactly is that i deleted a custom channel field while in the same time a new entry creation dialog was open in another browser tab. The concerned channel was using this custom field. Now when trying to edit this particular entry, i get the following error:
    You have tried to access a channel that does not exist.
    How can i repair this ? Im using EE 2.1.3, build 20101220
    Thank You.
  • #2 / Mar 30, 2011 4:45pm
    Hi, MedPro. You’ll need to manually edit two tables:
    exp_channel_titles
    -and-
    exp_channel_data
    to change the channel_id to something other than the value that’s in there now.
    Before you attempt this, be sure to make a backup copy of both tables, or your entire database.
    I’d suggest using PHPMyAdmin or something similar for this.
    Does that help?
  • #3 / Mar 30, 2011 5:39pm
    MedPro
    I dont understand what channel id i should use. I suppose i cant just use “any” number? If I change the associated channel_id, the entry will not belong to the right channel anymore, am i not right?
    The concerned entry has channel_id 19 associated with it. When i look into the table exp_channels, i can see a channel with the id 19. Table exp_channel_titles has one row with the value 19 as channel_id. Table exp_channel_data has no row with the value 19 as channel_id. Also the template which should display data from this channel, is not parsing the tags properly, displaying {field_name} on the output.
  • #4 / Mar 30, 2011 7:13pm
    Hi, MedPro. It can be any of your channel_ids, it’ll be associated to that particular channnel and you can delete the entry from inside of EE.
    Are there the same number of entries in exp_channel_titles and exp_channel_data?
  • #5 / Mar 31, 2011 5:48am
    MedPro
    Hi Sue, problem solved - i deleted the whole entry from the exp_channel_titles table.
    As for the answer to your question, the number of entries in exp_channel_titles and exp_channel_data was not the same - there was one entry less in exp_channel_data. Due to the error 1054, the entry could not be written into that table.
    Thank You very much for your help.
  • #6 / Mar 31, 2011 8:52am
    Glad that fixed it for you.. Feel free to start a new thread if you have any more questions.
