I’m getting the following error when invoking {exp:forum}:
“Unable to locate the following forum theme file: default/forum_index/forum_homepage.html”
If I change the default theme to anything else, the message stays the same which leads me to think it’s not pulling that info from where I think it should be.
Also, I have checked the themes folder and the folder/file exists.
More:
“http://www.oga.org/ogaeecp20/index.php/member/edit_profile/” returns the following error:
“The page you requested was not found”
Info:
The EE 1.6 install is located at “http://www.oga.org”, the EE 2.1.3 version is at “http://www.oga.org/ogaeecp20”. All other issues, CP logins, separate DB and all, seem to be working.
I have installed the discussion forum module - the correct one for EE 2.1.3
Any help or direction would be appreciated.
Bruce
