Customized conditional variables
March 15, 2011 10:07am
  • #1 / Mar 15, 2011 10:07am
    James.Lex
    Hi!
    Is there a solution where I can create my own conditional variables?
    For example: I want to have a customized variable called {allowed_member_groups}
    In the allowed_member_groups variable, I can declare the groups I want. I tried this with snippets but didn’t work.
    The snippet content is
    member_group==1 || member_group==10 ||member_group==8
    So it should be something like this:
    {if allowed_member_groups}
     Stand-alone-entry-form CONTENT
    {if:else}
     No access
    My goal here is to let the specified groups to have access with the Stand-alone-entry-form ONLY.
    I am not sure if this solution is the best. Maybe some of you have a brighter idea than this.
    best regards,
    Jay
  • #2 / Mar 15, 2011 8:46pm
    Hi, James -
    Snippets are parsed at the same time the templates are; as if they’re inline.  They do not change parse order.
    This may be a good case for a simple plugin where you can set those member groups right in the file, especially if you need to re-use this in many places.  There isn’t a way, outside of a plugin, to do this, though.
    If you’re interesting, here are the Developer Docs to get you started.
    Does that help?
    Edit to add: With the SAEF or SafeCracker (and we do recommend using SafeCracker now instead), the form won’t show unless you’re logged in with a member that can post to that channel.  For your particular example, a special conditional shouldn’t be required.  EE handles that.
  • #3 / Mar 16, 2011 5:46am
    JusTyMe
    Thanks for the suggestion. I do can CI actually but I am building a strong foundation with EE for now. That would be my next step actually. To work with CI on top of EE.
    I am using safecracker already but as far as I understand what you mean. Safecracker will do the magic if a user is authorized or not. I didn’t know about that. I will try it.
    Jay
  • #4 / Mar 16, 2011 6:13am
    JusTyMe
    By the way, I have an edit link to the SAEF. How is it possible to hide this link to members that has no priviledge to post to a certain channel?
    Maybe something like
    {if user_cant_post}
     You are not allowed to post in this channel
    {if:else}
     SAEF
    Any idea?
    Jay
  • #5 / Mar 16, 2011 1:52pm
    This is the conditional I use to hide the edit link to get to the SafeCracker form =)
    {if author_id == logged_in_member_id OR logged_in_member_group == "1"}
    • <a href="http://{path=thoughts/edit/{url_title}}">Edit This</a>
    I specify which member groups there, so you will need to know which member groups you allowed to post to that channel.
    Does that help?
    [Edit]  Sorry, that’s to edit.  To post:
    {if logged_in_member_group == "1"}
    <a href="your_url">
  • #6 / Mar 16, 2011 1:59pm
    Brandon Jones
    Hi Jay,
    There are a few approaches that will likely involve a bit of custom development, so moving this over to the CodeShare Corner.
  • #7 / Mar 16, 2011 8:13pm
    JusTyMe
    Does that help?
    <a href="your_url">
    Thanks for the input but that is actually the solution that I am doing now. I am sorry to tell you but I think this is a bit dirty. I mean having the same condition to multiple SAEF templates is a mess.
    Thanks anyway.
    Jay
  • #8 / Mar 16, 2011 8:20pm
    Hi, Jay -
    A plugin to check this more dynamically would be a great solution.  There may be one on Devot-ee, but otherwise you can have a look at our Dev Docs for information on how to build your own plugin.
  • #9 / Mar 21, 2011 8:26am
    JusTyMe
    Just coming back for a simple solution just in case someone will be needing this feature without the help of add-ons. I ended up creating a snippet called {edit_article} where I can use it anywhere.
    Here is the content of the snippet. Now I can reuse it anywhere and it is just a breeze adding or removing member groups that can access the link
    {if member_group==1 || member_group==8}
     <a href="http://link">Edit</a>
    {/uf}
    Thanks for your help anyway.
  • #10 / Mar 21, 2011 12:04pm
    Right, that was what I recommended? I’m a bit confused.  That’s also what’s in the Agile demo. =)
  • #11 / Mar 23, 2011 4:22am
    JusTyMe
    Partially 😉 Thanks for the support Lisa, I really appreciate it.
    cheers
