PHP Error and Blank Control Panel
March 10, 2011 4:49pm
  • #1 / Mar 10, 2011 4:49pm
    PJ4Quilts
    I was trying to change the theme on my site and did the unforgiveable and fogot to make a backup. So I tried to revert the site back to my previous backup.
    When I tried to access the Control Panel I was getting a Blank page, though I could see the site pages. The error points to the fruit CP theme which I was using with the last install but I wasn’t using fruit with the backed up install.  Where can I point the cp back to the default cp theme?
    Here is my error when I turned on de-bugging
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined property: CI_Loader::$view
    Filename: account/login.php
    Line Number: 6
    Fatal error: Call to a member function head_title() on a non-object in /home/xxxx/public_html/themes/cp_themes/fruit/account/login.php on line 6
  • #2 / Mar 11, 2011 5:37am
    PJ4Quilts,
    Are you familar with phpMyAdmin and would you be comfortable making a change in your database?
    If so open up the exp_members table. Your admin accoutn will be at row 1. Edit that and change the cp_theme to default
    If that doesnt do it then download the latest fruit them and upload that to your cp_themes folder
  • #3 / Mar 11, 2011 1:49pm
    PJ4Quilts
    Thanks, I did go into MyPHP and changed the CP to “default” and now I am getting these errors:
    Severity: Warning
    Message: filemtime() [function.filemtime]: stat failed for /home/xxxxxx/public_html/themes/cp_themes/default/css/global.css
    Filename: libraries/Cp.php
    Line Number: 158
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at /home/xxxxx/public_html/xxxxxx/codeigniter/system/core/Exceptions.php:166)
    Filename: core/Common.php
    Line Number: 424
    An Error Was Encountered
    Unable to load the requested file: account/login.php
    (I did check to make sure login.php was there and it is)
  • #4 / Mar 11, 2011 2:01pm
    PJ4Quilts
    Actually just tried it again, giving the database a moment of rest and this is the error I am getting
    Severity: Notice
    Line Number: 6
    Fatal error: Call to a member function head_title() on a non-object in /home/xxxxx/public_html/themes/cp_themes/default/account/login.php on line 6
  • #5 / Mar 11, 2011 5:02pm
    Hi, PJ4Quilts - are you on a Plesk hosting plan? Has your domain propagated yet? When I query for that error message, that’s what I found.
    http://ellislab.com/forums/viewthread/179375/
  • #6 / Mar 11, 2011 6:45pm
    PJ4Quilts
    Hi Sue, no not a plesk plan. Domain has been active on same hosting plan for a few years now.
    I was going to change the format of the site anyway so I guess this is as good a time as any to start from scratch.
    Is the best way to do that to remove everything and then upload all new files and then install?
  • #7 / Mar 12, 2011 5:42pm
    PJ4Quilts,
    What version and build of EE are you using? An upgrade might be the way to go here if you are behind a bit and may be the cause of your issue too if you are using a newer theme now.
  • #8 / Mar 12, 2011 8:24pm
    PJ4Quilts
    Hi John, I upgraded to the latest version 2.1.3 and build about 2 weeks ago, my backup that I have on hand was version 2.1.0. I try to keep it updated each version, I tend to skip most of the build updates.
  • #9 / Mar 13, 2011 9:07pm
    PJ4Quilts,
    Ok can I get you remove the fruit theme for now and re-download EE2.1.3 and just upload the themes inside cp_themes and see if that works for you
  • #10 / Mar 15, 2011 12:59pm
    PJ4Quilts
    Hi John, did as you asked, downloaded a fresh copy of 2.1.3 and then uploaded cp-themes folder.
    Also made sure in phpAdmin to make sure it said default and I am getting this error.
    Severity: Notice
    Line Number: 6
    Fatal error: Call to a member function head_title() on a non-object in xxx/xxx/public_html/themes/cp_themes/default/account/login.php on line 6
  • #11 / Mar 16, 2011 7:41am
    PJ4Quilts,
    Ok lets back up a while here
    That backup wasn’t for a different version of EE was it?
    Now check your server to see if safe mode is on or not.
    Open up your system/expressionengine/config/config.php and add the following lines after changing to your own path and url
    $config['theme_folder_path'] = '/path/to/themes/';
    $config['theme_folder_url'] = 'http://example.com/themes/';
  • #12 / Mar 16, 2011 11:57am
    PJ4Quilts
    Hi John, yes my backup was for a previous version, I had forgotten to backup the latest version.
    My config file says version 2.10
    I added the lines you specified. the “path” line was already there, so I added the “URL to the theme” line.
    Safe Mode is not on
    Still getting same result
  • #13 / Mar 16, 2011 1:06pm
    PJ4Quilts
    An update, I looked at this thread that was getting the same error message
    http://ellislab.com/forums/viewthread/179512/
    So I decided to upload the default theme from version 2.1.0 and I now have my control panel back.
    Thanks for your help John.
    Now I will upgrade to 2.1.3 and hopefully this time I won’t have anymore problems.
  • #14 / Mar 17, 2011 3:56am
    PJ4Quilts,
    Yeah sorry, should have caught that at the start that you reverted to an older version of EE’s database.
    I’ll keep this thread open for a while longer in case you have any issue upgrading
