Hello,
I’m trying to “idiot-proof” the Control Panel for a certain member group, and would like to know if there’s a way to remove the Multi-Edit functionality from the Edit Channel Entries page, as I only want this member group to be able to:
1) Edit entries one at a time
2) NOT be able to delete any of the entries listed on the page
3) Therefore, they would not see the red “Edit” or “Delete” buttons at the bottom of the page, nor would they see the column of check-boxes to the left of each entry.
Anyone know of a solution that would achieve this?
Many thanks,
Jenny
p.s. I’m already using the Zenbu Add-On to further reduce the amount of information visible on the Edit Entries screen.
