thumbnails in CP do not show up for other user with CP rights
March 09, 2011 6:54pm
Subscribe [6]
  • #1 / Mar 09, 2011 6:54pm
    sajwal
    I see the default image showing up for the thumbnails instead of the original thumbnails inside the control panel ....for a user provided access with admin privileges to the CP. The same happens with the safecracker form….I am using safecracker file for image field
    otherwise all thumbnails seem fine on the front end ... Please help
    Regards,
    sajwal
  • #2 / Mar 10, 2011 8:25am
    Hi, sajwal.
    Can you tell us which version/build of EE2.x you’re using? See EEWiki:// HowTo Determine My EE Version
    You mentioned SafeCracker - which version of SafeCracker?
    Let’s also check the amount of memory allocated to PHP…
    Have you seen: EEWiki:// HowTo Determine Memory Limits
    -and-
    EEWiki:// HowTo Override Memory Limitations
  • #3 / Mar 22, 2011 7:42pm
    Etheya
    I also have this current same problem… was there a fix for this? Im just seeing the default icon/image rather than a thumbnail of the ACTUAL IMAGE FILE in the CP, when using Safecracker File as a type of custom field.
    Would really appreciate a solution?
  • #4 / Mar 22, 2011 8:03pm
    Etheya
    It seems that when i import or use the existing file option on this fieldtype its not creating the (thumbs) directory or images within.. however if i use the browse button to choose an image then all is well. This however doesnt really help when you upload the images via FTP and just want to choose an existing file or as i have done here, import 500 lines of data with an image for each…
    All works on the front end just not in the CP, just get the default image unless i upload via the browse button.. which is a bit of a bind to say the least..
    Any ideas on a fix?
  • #5 / Mar 23, 2011 1:09pm
    Brandon Jones
    Hi Etheya,
    Am I correct in understanding that this only occurs with the SafeCracker File fieldtype, and not the built-in File fieldtype?
  • #6 / Mar 23, 2011 1:59pm
    Etheya
    Hi Brandon,
    Hard to tell 100% as ive not tried with the built-in file fieldtype as it doesnt allow me to state the upload destination.. which when the site is a gallery is not ideal.
    Like i said though, its only happening when..
    1) Batch upload the files to the correctly mapped folder via FTP
    2) Do a DataGrab import to a particular “Channel” of which one of the custom fields is setup as the Safecracker File field
    The images display fine on the front end… but if the client goes in to Content > Edit and chooses an entry.. the thumbnail displayed is just the default version. It doesnt seem to know to create the thumbnail.
    Where as if i add the image by using the browse and upload that way, it creates the thumbnail fine, which im presuming is generated on save etc.
    But with 600 images, descriptions and so on i would much rather import! worked fine before with Ngen File..
    Can you think of anyway around this issue?
  • #7 / Mar 24, 2011 9:34am
    Etheya, I vaguely remember seeing someone post a work around for creating thumbnails on the fly, I *think* it was Rob Sanchez, but I can’t find the reference right this second.
    Found it!
    I haven’t tested it personally.
    Does that help?
  • #8 / Mar 24, 2011 12:48pm
    Jérôme Coupé
    Etheya,
    Restored the thumbs using Rob’s script on many websites without problem after upgrading from ngen file field in 1.7. Works like a charm.
    Seems like the next version of EE will help with that as well.
  • #9 / Mar 24, 2011 1:08pm
    Thanks, jerome. Yes, that’s coming up in EE soon. 😊
    sajwal and etheya - how are you getting along?
  • #10 / Apr 26, 2011 11:59am
    Etheya
    Crap… still cant get the thumbs to show…
  • #11 / Apr 26, 2011 1:41pm
    Etheya,
    The dev team is working on upgrades to the File Manager that should fix the problem you’re having with thumbnails for FTPd images. I have quite a few to test with. 😊 That won’t help you today, but be assured we’re working hard on making sure this next release is solid. Thanks in advance for your patience.
  • #12 / Apr 27, 2011 6:19am
    Etheya
    Thanks sue… yeah its a bit annoying and hard to explain to the client…
  • #13 / Apr 27, 2011 6:24pm
    Brandon Jones
    Etheya, have you given the 2.1.4 beta a try?
  • #14 / Apr 30, 2011 10:09am
    Etheya
    Hi Brandon… i havent no.. mainly as its beta and this is on a live client site.. so i would be a little nervous about it. Is it a vast improvement at all?
  • #15 / Apr 30, 2011 12:41pm
    Greg Salt
    Hi Etheya,
    There are some significant changes to the File Manager. I suggest taking a look at it on a local install initially if you can.
    Cheers
    Greg
