Closing a snippet?
March 05, 2011 6:01pm
Subscribe [4]
  • #1 / Mar 05, 2011 6:01pm
    scruffpuff
    I have a snippet called ‘encodeHTMLchars’ that looks like this:
    {exp:tagstripper:tagsToStrip escapeHTMLchars='true'}
    This snippet needs to wrap some content:
    {encodeHTMLchars}something & something{/encodeHTMLchars}
    However I can’t just close encodeHtmlchars like that. Instead I have to define another snippet with the closing tag in it.
    Is there a way around this or is that pretty much the standard?
    EE2 v2.1.3
  • #2 / Mar 05, 2011 9:08pm
    Will Bolton
    Surely you don’t need to use a snippet in this case. Just wrap your content in the tagStripper plugin’s tags in your template:
    {exp:tagstripper:tagsToStrip escapeHTMLchars='true'}something & something{/exp:tagstripper:stripAllTags}
  • #3 / Mar 05, 2011 10:08pm
    Mark Bowen
    I’m with Will here. Would love to know exactly what you’re trying to do here because doing something like that in a template would be exactly the same as if you had just written it all in the one template in the first place surely?
    Best wishes,
    Mark
  • #4 / Mar 06, 2011 7:38pm
    scruffpuff
    Sure,
    So basically I’ve inherited a site which is powered by XML. The previous developer thought it wise to use XML attributes for almost every single aspect :\ As such, my template has a lot of attributes that all need to be encoded. The only reason I was using a snippet was to condense the amount of code on the page so that:
    could be shortened to
    {encodeHTMLchars}
    because it’s going to appear quite a few times.
  • #5 / Mar 06, 2011 8:21pm
    Will Bolton
    Ah, OK. I wondered whether there was a specific reason you were trying to do things that way, rather than it just being the case that you were a bit confused!
    In that case, I’m pretty sure the answer is that you will need two snippets - one to open, and one to close the tagStripper tags.
  • #6 / Mar 06, 2011 9:11pm
    scruffpuff
    cool thanks man 😊
  • #7 / Mar 07, 2011 9:33am
    scruffpuff - sounds like you’re all set. Thanks for the assist, Will and Mark.
    Feel free to start a new thread if you have any more questions.
