I need to get this code to render within my entry:
{edit_date format="%d. %m. %Y"}how can this be done, pls?
March 02, 2011 2:49pm
Subscribe [3]#1 / Mar 02, 2011 2:49pm
#2 / Mar 02, 2011 5:08pm
By default, EE tags go into templates, not entries. There is a plugin, but it might be better to restructure your site accordingly.
#3 / Mar 02, 2011 5:41pm
As John Henry Donovan mentioned here I could put the ee time format into an embed and have it sit within my entry - using the plugin you mention. That does not work for me!
I need an edit date within my entry.
Tks, Ingmar.
#4 / Mar 03, 2011 3:50am
Thomas,
Hey lets not go throwing names around here 😉
The method I mentioned in other thread works because it uses current_time which is not associated with the entry itself unlike edit_date which needs to remain in-between your channel:entries tags and not in an embed.
You could try Lows replace add-on
So in your entry rather than add an embed to the custom field, add a unique word or combination of letters and numbers within your text. Say ‘Re33’ for example
Then in your template add this
{exp:low_replace find="Re33" replace="{edit_date format='%d. %m. %Y'}"}
{your_custom_field}
{/exp:low_replace}That make sense? Untested by the way but you know, in theory 😊
#5 / Mar 03, 2011 4:38am
John,
i will try this and report back. Thank you!
#6 / Mar 03, 2011 10:48am
Sounds good, let us know what you find out.
#7 / Mar 03, 2011 1:03pm
John,
everything works exactly as you said - tks for that!
which variables other than current_time can i handle through an embed?
#8 / Mar 03, 2011 5:58pm
All global variables should work in a similar fashion.
#9 / Mar 04, 2011 3:05am
Ingmar, John!, Sue — Tk you all.
#10 / Mar 04, 2011 8:25am
Anytime 😉 Please post again as needed.
