No Discussion Forum Control Panel
February 21, 2011 4:51pm
  • #1 / Feb 21, 2011 4:51pm
    jsacket
    Hello,
    I am new to EE.  I just purchased EE2 along with the Forum Module.  As far as I can tell, the module installed correctly.  The tables where created and the config file has $config[‘forum_is_installed’] = “y”; .  However, when I Go to Add-Ons->Modules->Discussion Forums, it returns a blank page.  Any ideas?  I turned on CodeIgnitors Logging. When requesting this page, here is the output….
    DEBUG - 2011-02-21 20:49:03—> Config Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Hooks Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Unicode Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Unicode Class - UTF-8 Support Enabled
    DEBUG - 2011-02-21 20:49:03—> URI Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Router Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Output Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Input Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Global POST and COOKIE data sanitized
    DEBUG - 2011-02-21 20:49:03—> Language Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Loader Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: language_helper
    DEBUG - 2011-02-21 20:49:03—> Security Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Database Driver Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: string_helper
    DEBUG - 2011-02-21 20:49:03—> Security class already loaded. Second attempt ignored.
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/core_lang.php
    DEBUG - 2011-02-21 20:49:03—> User Agent Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/cp_lang.php
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: form_helper
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: quicktab_helper
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: security_helper
    DEBUG - 2011-02-21 20:49:03—> Jquery Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Javascript Class Initialized and loaded.  Driver used: jquery
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: url_helper
    DEBUG - 2011-02-21 20:49:03—> Model Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/addons_lang.php
    DEBUG - 2011-02-21 20:49:03—> File loaded: /var/www/sites/okbandmasters/themes/cp_themes/default/_shared/menu/item_parent.php
    DEBUG - 2011-02-21 20:49:03—> File loaded: /var/www/sites/okbandmasters/themes/cp_themes/default/_shared/menu/item.php
    DEBUG - 2011-02-21 20:49:03—> File loaded: /var/www/sites/okbandmasters/themes/cp_themes/default/_shared/menu/item_divider.php
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: directory_helper
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: file_helper
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/expressionengine_info_lang.php
    DEBUG - 2011-02-21 20:49:03—> Helper loaded: version_helper
    DEBUG - 2011-02-21 20:49:03—> Controller Class Initialized
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/modules_lang.php
    DEBUG - 2011-02-21 20:49:03—> Addons class already loaded. Second attempt ignored.
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/forum_lang.php
    DEBUG - 2011-02-21 20:49:03—> Language file loaded: language/english/forum_cp_lang.php
  • #2 / Feb 22, 2011 8:15am
    Welcome to the ExpressionEngine forums, jsacket.
    Since you’re new to the EE forums, have you seen EEWiki:// How to Post a Support Request?
    Often times this problem can be caused by a lack of memory allocated to PHP.
    Have you seen: EEWiki:// HowTo Determine Memory Limits
    -and-
    EEWiki:// HowTo Override Memory Limitations
    How much memory is allocated to PHP?
