I am including the Disqus Comment Javascript code into a snippet to be used on all pages.
In the code it recommends entering a variable for the following two lines:
// var disqus_identifier = 'unique_dynamic_id_1234';
// var disqus_url = 'http://example.com/permalink-to-page.html';
What variable should I replace “unique_dynamic_id_1234” with?
What variable should I replace “http://example.com/permalink-to-page.html” with?
I was hoping there would be a global variable for both but doesn’t seem to be the case. Now there are single variables for the channel entries tag but not sure how that would work since I wish to use on snippet for all channels and pages. Such as, would the below work for all channels and pages? Thanks in advance!
{exp:channel:entries}
var disqus_identifier = '{entry_id}';
var disqus_url = '{permalink}';
{/exp:channel:entries}Cheers,
Christopher Beckwith
[Mod Edit: Moved to the CodeShare Corner forum]
