char_limit not evaluating within checkbox field
February 09, 2011 1:13am
  • #1 / Feb 09, 2011 1:13am
    Mitch Cohen
    I’m finding that exp:char_limit isn’t evaluating when within a checkbox field loop.
    In the following code, h_displayoptions is the name of a checkbox field, where “Top Headline” is one of the options:
    {exp:channel:entries channel="News" orderby="date" show_future_entries="no" limit="10" dynamic="no" show="1|13|12|9|4|24" }
    {h_displayoptions}
        {if item=="Top Headline"}
            <a href="http://{title_permalink=/newsevents/news_detail}">{title}</a>
            {entry_date format="%l, %F %d, %Y, %g:%i %A"}
            {exp:char_limit total="100"}
                {h_details}
            {/exp:char_limit}
    <a href="http://{title_permalink=/newsevents/news_detail}">full story</a>
    {/h_displayoptions}
    The above works fine, except that the output contains the {exp:char_limit total="100"} code, followed by the full (multi-paragraph) h_details, followed by {/exp:char_limit}.
    If I remove the checkbox field loop (and fake the if/then to function):
        {if item!="Top Headline"}
                {h_details}
            {/exp:char_limit}
    The char_limit works as expected, trimming h_details to 100 characters.  Of course I’m then ignoring the checkbox, which I don’t want to do.
    Any suggestions?  Thanks!
  • #2 / Feb 09, 2011 3:26pm
    Have you tried specifying a parse order explicitly?
  • #3 / Feb 09, 2011 9:32pm
    Mitch Cohen
    I have, with no change.
    There’s definitely something odd happening within checkbox loops.  Key to the above is that the {exp:char_limit total=“100”} code appears in the generated HTML.  It’s not a problem with char_limit; same happens with third-party truncating plugins I’ve found.  Just spits the EE code back out again.  Tried in a standalone template, fails there too.
    I’m really wracking my brain on this one. Seems very straight-forward, and I really need this to work.  I’d be fine using PHP but I can’t get that sorted out here either.  Any suggestions appreciated.
  • #4 / Feb 09, 2011 9:48pm
    Mitch Cohen
    As additional followup…  I created a template with nothing but this code:
    {exp:channel:entries channel="News" orderby="date" show_future_entries="no" limit="10" dynamic="no" show="1|13|12|9|4|24"}
        {h_displayoptions}
            {exp:char_limit total="10"}
                Now is the time for something whatever hip hip hooray.
            {/exp:char_limit}
        {/h_displayoptions}
    There are two entries in the News channel with options set for the h_displayoptions entry checkbox.
    You’d think the browser would display something like:
    Now is the time for
    Now is the time for
    But the results are (from a browser’s View Source):
            {exp:char_limit total=“10”}
            {/exp:char_limit}
            {/exp:char_limit}
    It’s looking like the checkbox parsing is converting everything to entities, preventing char_limit from reading its “limit” parameter.
  • #5 / Feb 10, 2011 10:24am
    Sounds buggy to me too.. Can you tell us which version/build of EE2.x you’re using? See EEWiki:// HowTo Determine My EE Version
  • #6 / Feb 10, 2011 10:27am
    Mitch Cohen
    v2.1.3, Build:  20101220
    Thanks.
  • #7 / Feb 10, 2011 3:46pm
    Could you try upgrading to 2.1.4? Or, perhaps, in the meantime try one of the other available limiter plugins, like TruncHTML?
  • #8 / Feb 11, 2011 3:15am
    Mitch Cohen
    I tried TruncHTML and Power Truncate.  Same results as shown above.  The issue appears to be the conversion of contents of the checkbox loop to HTML entities and lack of EE processing.  Note the markers in the source; that’s not from the EE code or my HTML.
    I’m near deadline so can’t try the beta.  I’ll try it on a test server when I have a few minutes.
  • #9 / Feb 11, 2011 12:18pm
    Thanks Mitch, please let us know how it goes. I’m trying to reproduce as well.
