Conditional Custom Field?
February 05, 2011 6:27pm
  • #1 / Feb 05, 2011 6:27pm
    heavymark
    I read the document on conditional global variables which is great. But I’d like to do the same with a custom field.
    Would this be the proper format?
    {if {link_rel} != ""}rel="{link_rel}"{/if}
    In which I’m saying if the custom field “link_rel” contains no value, do not show anything between that if statement, but if “link_rel” does have a value, show the contents between the if tags. Or is their a different more efficiently way of doing this in EE2. Thanks!
  • #2 / Feb 05, 2011 6:41pm
    Focus Lab Dev Team
    In my experience it’s most reliable to use quotes around the custom field in the conditional. However, I imagine there may be some type of conflict if the custom field value has the same quote (single or double) in it.
    So, something like this is what we use:
    {if "{link_rel}" != ""}rel="{link_rel}"{/if}
    I’m interested if there is an advised method though.
  • #3 / Feb 05, 2011 6:44pm
    heavymark
    Great, thanks, I’ll add the quotes. Now my syntax highlighting looks more proper.
    Luckily the value of this field would not ever contain quotes, but I will keep that in mind for future uses.
  • #4 / Feb 05, 2011 8:22pm
    Quoting and bracing conditionals can create security issues, especially when the data can come from user input, such as segments.  See point 5 in troubleshooting conditionals
    A variable having to be quoted can be a sign that the code generating the variable is not being run through prep_conditionals, or that the conditional isn’t written correctly as in the original post. =)  See conditional global variables for proper syntax.
    heavymark - the correct and safe way to write your conditional is:
    {if link_rel != ""}rel="{link_rel}"{/if}
    Hope that helps!
  • #5 / Feb 06, 2011 10:13am
    heavymark
    Thanks Lisa!
  • #6 / Feb 07, 2011 8:27am
    Glad Lisa was able to help. Don’t hesitate to post again as needed.
