I am happy and very exited to announce the release of Zenbu, a built-from-scratch ExpressionEngine 2.x module that is similar to the “Edit channel entries” section, but lets you see more than simply basic entry data, including sticky status, data stored in custom fields and more. The module (and accompanying extension), can be used as a replacement to the built-in “Edit channel entries”.
Although I’m the developer, I can tell you that Zenbu saves me a lot of time looking at entry data: instead of clicking each entry, load its entry form, then scroll through the fields, Zenbu lets me see data from multiple entries at a glance, all in one place. This makes it a great way to troubleshoot what clients have entered in custom fields, for example. Clients also love the ability to quickly see their data, including uploaded image files, which facilitates their daily entry management.
The list of features is quite extensive, and I plan to add more features in the future. Details can be found at my site.
Zenbu is a commercial addon available at Devot://ee.
P.S. I would like to thank Koen Veestraeten from StudioKong for his excellent and detailed reporting during the beta phase.
