Upgrade issues 2.1.3 to 2.1.4
February 03, 2011 3:11pm
Subscribe [4]
  • #1 / Feb 03, 2011 3:11pm
    adamwiggall
    Team,
    I’m running an install of 2.1.3 on a local MAMP box and a remote server (at EngineHosting). I am version controlling changes between the two using GIT and both installs are running off a separate database.
    In order to accommodate the separate databases I am performing a server http host check in my database.php file like so,
    if ($_SERVER['HTTP_HOST'] == "dev.localdevsite.com") {
        $active_group = 'localdev';
    } else {
        $active_group = 'expressionengine';
    Today I attempted to upgrade the install to the 2.1.4 Beta (on the MAMP install) and hit ‘can’t connect to database’ error (controllers/wizard.php line 1452).
    Looking at wizard.php around the error I saw that line 1488 is trying to connect to the remote DB
    $this->load->database($db['expressionengine'], FALSE, TRUE);
    I got around the issue by editing the file to load my local MAMP DB like so
    $this->load->database($db['localdev'], FALSE, TRUE);
    I could then perform the update locally, sync changes to the remote server and continue on (thankfully).
    I was wondering whether this would be considered a bug as the $active_group method for DB config is the recommended method?
    Could the wizard look for the active group and make it changes based off that?
  • #2 / Feb 04, 2011 8:22am
    Hi, Adam. Why don’t you put it in the bug tracker, and the devs will decide if it is one or not. 😊 I honestly don’t know, but this way it’ll be there just in case it is. Make sense?
