Your config file does not appear to be formatted correctly.
February 01, 2011 4:32pm
Subscribe [6]
  • #1 / Feb 01, 2011 4:32pm
    spasmoid
    I just got a fresh download of
    Current Version: 2.1.3 - Build: 20101220
    installing on windows 7 (64bit) localhost, PHP Version 5.3.1,  (xampp)
    Apache/2.2.14 (Win32) DAV/2 mod_ssl/2.2.14 OpenSSL/0.9.8l mod_autoindex_color PHP/5.3.1 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1
    First attempt at accessing it gave me this error
    fresh install, changed “system” folder to something else and updated index.html
    Still same error. I made sure the “everyone” group had “Full Control” permissions.
    any ideas?
  • #2 / Feb 02, 2011 9:51am
    Hi, spasmoid.
    Are you attempting to install into a directory other than /system? What did you put in for the value to the folder? Remember Windows slashes are different than Unix ones.
  • #3 / Feb 02, 2011 11:03am
    spasmoid
    I just changed it like so
    $system_path = './cp';
    I was under the impression that unix slashes are transposed to windows slashes by the PHP engine. In any case, changing the above value from a forward slash to a back slash has made no difference.
  • #4 / Feb 02, 2011 5:26pm
    My mistake, I saw Windows and leapt to the wrong conclusion. You’re taking about a local install using xampp..
    I use MAMP, and haven’t used xampp in a few years.
    If you run the Server Wizard, what does that say?
  • #5 / Feb 02, 2011 8:21pm
    wasserstrom
    I’m actually trying to this right now with MAMP and getting the same error about the config file. I made sure to set the permissions properly. What’s going on? Thanks!
  • #6 / Feb 02, 2011 8:28pm
    spasmoid
    I did a quick google on this and it seems that other people have had this issue but no one has solved it. Surely it is solvable.
  • #7 / Feb 02, 2011 8:50pm
    spasmoid
    I have found that
    system\expressionengine\config\config.php
    is zero bytes long (empty).
    and so is
    system\expressionengine\config\database.php
    This is from a fresh download. Are these files supposed to be empty in the distribution???? What gives?
  • #8 / Feb 02, 2011 8:54pm
    wasserstrom
    I believe they are supposed to empty in the distribution. I’m not sure there’s any more configuring to do after we set the permissions though.
  • #9 / Feb 03, 2011 1:03am
    3Easy
    It is correct that the config.php file in a freshly downloaded copy of the software will be empty, the installation process populates it. Likewise with the database.php file. Say, wasserstrom, can you confirm the error message. Follow the installation steps through again carefully, report the exact message. Cheers.
  • #10 / Feb 03, 2011 4:39am
    spasmoid
    @Sue, re: ee_wizard,
    Everything says yes except for “URL segment support” (suggested).
  • #11 / Feb 03, 2011 4:30pm
    That sounds good. When you visit http://localhost/system/index.php, are you getting the same error message?
  • #12 / Feb 05, 2011 9:19am
    spasmoid
    No. I don’t get the error if I go into the system dir. It begins the installation wizard.
    Weird.
    None the less. Thanks!
  • #13 / Feb 06, 2011 2:19pm
    Greg Salt
    Hi spasmoid,
    Glad that you have this sorted now. The behaviour you describe is correct and as per the documentation you must point your browser to the system directory (or whatever it is renamed as) to start the Installation Wizard.
    @wasserstrom, how are you getting on?
    Cheers
    Greg
  • #14 / Feb 06, 2011 4:24pm
    spasmoid
    Thanks for clearing that up for me Greg.
  • #15 / Feb 07, 2011 3:14pm
    Very glad to see you’re all set. Please post again as needed.
