Upgrade from 1.7 to 2.1.3: Content truncated after characters such as "æ", "ø" and "å"
January 29, 2011 1:24pm
  • #1 / Jan 29, 2011 1:24pm
    Pål Degerstrøm
    I have a fully functioning site running 1.7, that I want to upgrade to version 2.1.3. The upgrade wizard completes with no errors, but when I log in to the control panel all content is truncated after characters such as “æ”, “ø” and “å” (this is a Norwegian site). Even my control panel username is truncated from “Pål Degerstrøm” to simply “P”.
    I’ve down- and upgraded the site twice, and it happened both times.
    Is anyone able to help?
  • #2 / Jan 29, 2011 2:08pm
    Greg Aker
    What is your table charset and collation after your update?  Is it properly converting everything to UTF8?
  • #3 / Jan 29, 2011 2:27pm
    Pål Degerstrøm
    Hi Greg,
    I started investigating a bit after posting, and found a solution (that worked for me, at least). My database was utf-8 and utf8_general_ci, so I commented out the conversion code in the function convert_db_to_utf8() in the file ud_200.php (I left the return ‘standardize_datetime’; bit). I did the update, and everything seems fine.
    Perhaps the conversion from (in my case utf8/utf8_general_ci to) latin1/latin1_swedish_ci back to utf8/utf8_general_ci is doing some harm? It seems to have done for me, in any case. You can close this thread, I will repost if my hack causes me problems 😊
    Let me know if you’d like a database dump for debugging.
  • #4 / Jan 30, 2011 12:44pm
    Greg Salt
    Hi Pål,
    Okay, I’ll close this thread. Thank you for the update.
    Cheers
    Greg
