Order Members by Custom Member Field
January 26, 2011 8:16am
Subscribe [4]
  • #1 / Jan 26, 2011 8:16am
    GlobalGraphics
    Hi There,
    I want to order my members on the contact page of my site. However I need to be able to ajust the order from time to time. I have therefore created a custom member field called display_order and told EE to display this on the site like so:
    <ul id="users" class="container">
      {exp:query sql='SELECT member_id, email AS "email_plain" FROM exp_members WHERE member_id <> 1 AND group_id = 1 OR group_id = 6 ORDER BY screen_name'}
      {exp:member:custom_profile_data member_id='{member_id}' parse='inward' order_by='display_order' sort='asc'}
      <li>
        {if avatar}
        {avatar_url}
        {if:else}
            {site_url}images/uploads/img_defaults/{default_staff_image}
        <ol>
          <li>{screen_name}</li>
          {if position != ''}<li><strong>{position}</strong></li>
            {if:else}
            <li>Position Not Entered</li>{/if}
          <li>{email}</li>
        </ol>
      </li>
      {/exp:member:custom_profile_data}
      {/exp:query}
    </ul>
    The part I am editing without much success is the line:
    I am not having much success. Can anyone see what the problem is?
    Thanks.
  • #2 / Jan 26, 2011 5:42pm
    {exp:member:custom_profile_data} does not support an order_by= parameter, I am afraid. Perhaps you should be doing all of this within the SQL query?
  • #3 / Jan 27, 2011 4:30am
    GlobalGraphics
    Ok, so can you give me an example of what I should be doing?
  • #4 / Jan 27, 2011 5:14pm
    Another question.. is position and the sort order the only thing you want to have in the custom member fields?
    What are you trying to order?
  • #5 / Jan 28, 2011 4:36am
    GlobalGraphics
    I also have Job Title as a custom field.
    The members are displayed on the contact page in a list and I want to be able to change their order. Not by date or id but by a custom field.
    Thanks.
  • #6 / Jan 28, 2011 3:08pm
    Are you familiar with the syntax for joining tables in a SQL query? You’ll need to build a query to display what you want. But the problem is that there are two tables you’ll need to join.
  • #7 / Jan 31, 2011 4:46am
    GlobalGraphics
    Hi Sue,
    No I am not familiar with how to do that. Can you please give me an example?
    Thanks.
  • #8 / Feb 01, 2011 2:25am
    GlobalGraphics,
    I can’t give you an exact query unfortunately but here is an example of a join
    {exp:query sql="
    SELECT exp_categories.cat_id AS cat_id,exp_categories.cat_url_title AS cat_url_title
    FROM exp_categories
    JOIN exp_category_posts
    ON exp_categories.cat_id=exp_category_posts.cat_id
    WHERE
    exp_category_posts.entry_id = {entry_id}"
    I can move this thread to the CodeShare Corner if you wish and let the community get involved?
  • #9 / Feb 01, 2011 4:42am
    GlobalGraphics
    Hi John,
    Yes please codeshare corner sounds great.
    Thanks.
  • #10 / Feb 01, 2011 7:52am
    Moving as per request.
  • #11 / Feb 01, 2011 8:08am
    GlobalGraphics
    Hello Codeshare corner!
    Can anyone give me an example of what I need to do here?
    Thanks.
