I’ve got an invite to tender for a large project where the client is open to CMS suggestions and can internally supply the hosting requirements for EE2. They have a requirement that some sections of the new site will need to access and write to a corporate level Microsoft SQL Server CRM database. This is an absolute requirement.
I’ve looked through the forums and I know that EE2 doesn’t directly support ms sql database connections, but I was wondering if it would be feasible to use CI based modules only for those particular sections of the site where access to the ms database is required?
Could you advise if this is a practical solution or if there are other approaches that could be considered?
Darrell
