Hi all,
I’m using the latest version of EE (2.1.3 Build 20101220), but am having an issue with the links to entries from the Edit Channel Entries page.
In previous versions of EE2 (ie. 2.1.1) the links were generated WITH their correct “entry_id” in the URL. So in the Edit Channel Entries list if I click on the link to edit entry_id “2” (lets call it the “About us” entry) the link would be (if viewed directly from the source):
<a href="http://index.php?S=8cd90f44545b00e1e88dac6cd69d513c73ad4a7d&D=cp&C=content_publish&M=entry_form&channel_id=1&entry_id=2">About us</a>Simple! This makes complete sense!
Now in EE2.1.3 it seems that jQuery is being used to create the “entry_id”. So if the “About us” entry was first in the list, the link would be (again, if viewed directly from the source):
<a href="http://index.php?S=8cd90f44545b00e1e88dac6cd69d513c73ad4a7d&D=cp&C=content_publish&M=entry_form&channel_id=1&entry_id=0">About us</a>After the page has finished loading, some jQuery is called to run through all the entries listed to change the “entry_id” to the correct id.
SO… to my issue….
This is causing issues when a user clicks on the link BEFORE the page has finished loading. They are taken to either the WRONG entry, or if the entry_id is set to 0 (which the first one is), then they are taken to a Publish New page.
Is this by design, or a bug? Thoughts?
Cheers.
