Comment module - results blank
January 20, 2011 4:58pm
  • #1 / Jan 20, 2011 4:58pm
    David M
    I have some experience building sites in EE, but believe it or not I haven’t had a need to build a simple blog using EE… until now. I’m trying to build the template for a blog index page that simply shows the last 10 entries. One piece of data I want to display beneath each entry (on the index page), is the number of comments received. This is in EE 1.6.9.
    To keep it simple, I tried this:
    {exp:comment:entries}
    {absolute_count} comments
    {/exp:comment:entries}
    The results come back completely blank—the entire paragraph element and all the text inside is missing from the source.
    I’ve tried this both inside of the {exp:weblog:entries} tag and outside of it. I’d tried adding weblog and entry_id parameters to the {exp:comment:entries} tag but nothing seems to have an effect. Comments are enabled for the weblog, as well as the individual entry. I would expect it should tell me that there are zero comments.
    I must be missing something really simple…
  • #2 / Jan 21, 2011 9:27am
    Try {comment_total}. It’s part of {exp:weblog:entries}, no need to invoke {exp:comment:entries}.
  • #3 / Jan 21, 2011 12:10pm
    David M
    Thanks, Ingmar. That seems to just work just fine for showing the number of comments on the index page.
    However, when I try to use {exp:comment:entries} on the page that shows just the specific blog entry and its comments, the same behavior is exhibited—that is, nothing between {exp:comment:entries}...{/exp:comment:entries} is output in the source. I’ve tried including or removing various parameters, with no success.
    (I can successfully add a comment form and submit a comment. The count is updated properly on the index page, but {exp:comment:entries} still appears to choke on the entry page.)
  • #4 / Jan 22, 2011 2:12pm
    Greg Salt
    Hi David,
    Can you please let us know the URI that this comment is supposed to be on and whether the last segment is a URL Title or not. Also, please post the code you are using for your comment entries tag.
    Cheers
    Greg
