Single quotes in title field are converted to curly quotes
January 20, 2011 10:09am
Subscribe [5]
  • #1 / Jan 20, 2011 10:09am
    Leon Dijk
    When I use an entry title such as
    This shouldn't be a qurly quote
    and use the exp:channel:entries tag to output the title, the single quote is being converted to a curly quote.
    I’ve searched and found some related posts, but couldn’t find a clear answer. Also, I think most of those problems were with EE1.
    When I look the entry up in the database, it shows a normal single quote. So the conversion happens on output.
    My doctype:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html >
    Charset:
    <meta http-equiv="content-type" content="text/html; charset=utf-8" />
    but I’m quite positive that’s not the problem, as my pages show normal quotes when I enter them directly in a template like this for example:
    <h1>This shouldn't be a qurly quote</h1>
    Any ideas? I’m using EE 2.1.3, although this also happened with 2.1.1 I think.
  • #2 / Jan 20, 2011 4:30pm
    Yes, it’s the typography parser. For a custom field it’s usually sufficient to choose “Formatting: None” instead of XHTML.
  • #3 / Jan 20, 2011 4:35pm
    Leon Dijk
    I understand, but it happens on the default Title field, for which I can’t set any formatting as far as I know?
  • #4 / Jan 21, 2011 9:44am
    I am looking into this. Thank you for your patience.
  • #5 / Jan 21, 2011 11:15am
    I am afraid that you’d need to use a plugin around the title field in the template to change it; you can’t change it with a setting in EE. Alternatively you could use a secondary title field which, as a regular custom field, can be formatted as desired.
    Sorry I have no better news. Feel free to make a Feature Request, too.
  • #6 / Jan 21, 2011 2:23pm
    Leon Dijk
    Hi Ingmar,
    Thanks for taking the time to look into this!
    It strikes me that this is standard behavior. If I enter a quote and it gets stored as a quote in the database, I don’t expect it to be converted into a curly quote by the exp:channel:entries tag.
    Before I started this thread, I spent hours looking for a reason why it converted my quotes..server settings, EE settings etc. Sure, I could create a secondary title field or use a find and replace plugin like you suggested, but it is what it is: a workaround for something that shouldn’t happen in the first place. I am currently using the find/replace method, but since I use the title field for quite a few purposes (h1 tag, breadcrumbs, social network api’s etc), it’s not ideal.
    Thanks again for your help and suggestions, I’m going to submit a feature request!
    Leon
  • #7 / Jan 22, 2011 3:08pm
    Greg Salt
    Hi Leon,
    The title variable data should properly convert single quotes into the HTML code:
    Is this not happening for you? This behaviour was changed some time ago in the EE 1.x branch in order to make sure that titles were valid HTML. Up until then titles had to be wrapped a typography plugin.
    Cheers
    Greg
  • #8 / Jan 22, 2011 7:49pm
    Leon Dijk
    Hi Greg,
    Yes, that is what my installation of EE does, it converts a single quotation mark into a “right single quotation mark”:
    ..which is not the same as a single quote. When I enter a single quote in the title field, it should stay a normal single quote and shouldn’t be converted into a right single quotation mark. So, it should be this instead:
    Also, when I copy/paste a right single quotation mark (not the HTML entity equivalent, but the actual character) into the title field and then display it on a page with the exp:channel:entries tag, it isn’t being converted into its HTML entity equivalent, which seems kind of strange as well.
    I hope this makes sense. To me, it looks like a bug. See http://www.ascii.cl/htmlcodes.htm for example for a list of ASCII characters, you’ll see that the single quote should be &#39; and the right single quotation mark should be &#8217;
    Leon
  • #9 / Jan 24, 2011 2:25am
    Leon,
    For now please go ahead and make a Feature Request as suggested.
    These requests are read by our devs all the time
  • #10 / Jan 24, 2011 4:17pm
    Leon Dijk
  • #11 / Jan 24, 2011 4:21pm
    Glad to see that cleared it up. Please don’t hesitat to post again as needed.
