slider show matching
January 14, 2011 4:22pm
  • #1 / Jan 14, 2011 4:22pm
    Dominik Lechner
    Hello i would like that all property “villas” in my bargain slideshow properties tool are displayed
    http://www.mallorca-properties.co.uk/villa/pollensa/
    ( right navigation)
    The matching dont work!!
    {exp:weblog:entries weblog="properties" limit="4" show_future_entries="yes" disable="categories|member_data|pagination|trackbacks" orderby="random" search:property_bargain="=y"&property;:_type=“Villa" dynamic="off"}
    i try it with : search:property_bargain=”=y” search:property;_type=“Villa”
    but dont get a result with all villas… :-(
    Hope somebody can help!!
    Thx..regards
    dominik
  • #2 / Jan 20, 2011 12:16pm
    smartpill
    ( right navigation)
    Thx..regards
    dominik
    Do you actually have a semicolon in your field name (property;_type)? I don’t think that would be valid. Try:
    search:property_bargain="=y" search:property_type="Villa"
    instead. Also would the value of property_bargain be “=y” or just “y”? If it is a checkbox, most likely it is “y” so in that case:
    search:property_bargain="y" search:property_type="Villa"
  • #3 / Jan 20, 2011 12:49pm
    Dominik Lechner
    Hi Thanks a lot works perfect now.
    {exp:weblog:entries weblog="properties" limit="9" show_future_entries="yes" disable="categories|member_data|pagination|trackbacks" orderby="random" search:property_featured="=y" search:property_type="Villa"  dynamic="off"}
    When a client search a villa in pollensa
    so all villas from the island are featured on the right box but i would like to prefer that all villas in a “City” is displayed
    Do you know a solution?? I try this code….but dont work :-(
    search:property_featured="=y" search:property_type="Villa"  search:property_city="property_city" dynamic="off"}
  • #4 / Jan 25, 2011 3:53pm
    Dominik Lechner
    Mhh…the propery typ works perfect…but i need some help about the city´s
    Hope anyone can help me!
    Dominik
