Weblog:entries across MSM
January 14, 2011 1:56pm
  • #1 / Jan 14, 2011 1:56pm
    Spurlock
    I’m having trouble pulling content from other sites under MSM (previously I thought this was related to Playa, but I’ve distilled the issue to pure EE).
    I’ve reduced my template to
    {exp:weblog:entries site="news" weblog="directory" dynamic="off"}
    <h1>{title}</h1>
    {/exp:weblog:entries}
    This template is in a different site on the MSM installation.
    Template debugging says “Returning No Results Content”. What am I missing?
  • #2 / Jan 14, 2011 6:59pm
    Spurlock:
    Can you tell us which version/build of EE1.x you’re using? See EEWiki:// HowTo Determine My EE Version
  • #3 / Jan 18, 2011 9:16am
    Spurlock
    We’re using 1.6.8, Build 20100121
  • #4 / Jan 18, 2011 10:31pm
    Is the short name of the site news?
  • #5 / Jan 19, 2011 9:29am
    Spurlock
    It is.
  • #6 / Jan 19, 2011 1:44pm
    Unfortunately site= and search: do not work together.  search: will always be on the current site.
    You’re welcome to make a feature request for an expansion to this behavior.  For now, you might need some custom queries to pull that data across.
  • #7 / Jan 19, 2011 3:20pm
    Spurlock
    Lisa,
    Thanks for the tip, it will probably save me a lot of headache down the road. However, the code sample above doesn’t use the search parameter. Unless I’m mistaken, it ought to simply pull all entries from the specified weblog on the other site. Is search somehow implicit in what I posted?
    As far as I can tell, I’m unable to use weblog:entries to pull data from one site to another in any way.
  • #8 / Jan 19, 2011 3:33pm
    Sorry Spurlock.  I saw something that wasn’t there.  That’s my fault.
    Are you sure you have a weblog “directory” on the “news” site?  Does that code work on the originating site?
    Those would be good things to double check first. =)
  • #9 / Jan 19, 2011 3:47pm
    Spurlock
    I completely understand your skepticism 😊
    Screenshots: http://imgur.com/miThh
    It seems like a really weird issue, I sort of hoped there might be some kind of admin setting for “allow cross-site entry queries” or something, because I’m not sure what else would explain it. Is there anything about the server environment to look out for?
  • #10 / Jan 19, 2011 3:56pm
    Spurlock
    Actually, that other suggestion about the code working on the originating site turned out to fruitful.
    The “news” site is one that I didn’t set up myself, and unbeknownst to me the “directory” weblog was making (bizzare and unnecessary) use of custom statuses…
    Adding the status group to the query fixed it. Sorry for the trouble, and thanks for the help!
  • #11 / Jan 19, 2011 4:00pm
    Hey Spurlock!  Those custom statuses, they do sometimes manage to catch people out.  Glad you figured it out!
    If anything else comes up, please start a new thread so that we can help you out.
