Pages Module and URL parameters
January 14, 2011 10:17am
Subscribe [4]
  • #1 / Jan 14, 2011 10:17am
    Fuel
    On the sites that we build, there’s a certain number of url parameters that we look for via an .htaccess file. For example, Google Analytics tracking parameters may look something like this : http://domain.com/?cmpid=12345
    Generally we do not have any issues with these, but we are with URIs created with the Pages module. Is there any way for a URI created with the Pages module, with attached URL parameters (ex. http://domain.com/about/?cmpid=12345 ) to ever work properly? Has anyone seen any tutorials or posts that may have a potential workaround?
    This is for EE2 by the way, but could apply to both EE1 and EE2 I assume.
  • #2 / Jan 14, 2011 5:03pm
    What happens when you try and create a URL like that using the Pages module?
    Can you tell us which version/build of EE2.x you’re using? See EEWiki:// HowTo Determine My EE Version
  • #3 / Jan 14, 2011 5:33pm
    Fuel
    Hi Sue, Thanks for taking a look at this issue.
    I’m not really looking to create a URI with the parameters in it. I want to make sure that any page created via the Pages Module can render properly with tracking parameters attached to it. In other words, there could be multiple variations of these parameters.
    I did a little further testing with a few other sites, both EE1 and EE2 at different versions.
    - All of the EE1 (versions 1.6.7 and 1.6.8) sites seem to handle this without issue.
    - All of the EE2 sites (versions 2.1.0 and 2.1.1) that I’ve tested produce a 404.
    I will upgrade a site to 2.1.3, test it and report back as soon as I can.
  • #4 / Jan 14, 2011 6:20pm
    Fuel
    I have tested a 2.1.3 site and the result is the same. Always a 404 error.
  • #5 / Jan 15, 2011 3:06pm
    Greg Salt
    Hi Fuel,
    Can you clarify what it is that you are doing in the .htaccess file for these URIs?
    Cheers
    Greg
  • #6 / Jan 16, 2011 12:50pm
    Fuel
    Hi Greg,
    We’re using the NSM htaccess generator add-on to remove index.php. So we have a few rules to overcome some issues where tracking parameters get lost or send users to 404 pages.
    #Rewrite homepage urls that have the cmpid query string
    RewriteCond %{QUERY_STRING} ^cmpid [OR]
    RewriteCond %{QUERY_STRING} ^test [OR]
    RewriteCond %{QUERY_STRING} ^utm_(.*) [OR]
    RewriteCond %{QUERY_STRING} ^showdebug [OR]
    RewriteCond %{QUERY_STRING} ^tollfree
    RewriteCond %{REQUEST_URI} ^/$ [NC]
    RewriteRule (.*) /index.php?/site/index/&%{QUERY_STRING} [L]
  • #7 / Jan 17, 2011 2:10am
    Fuel,
    Make sure in your config.php file that you have changed
    $config['uri_protocol']    = 'AUTO';
    to
    $config['uri_protocol']    = 'PATH_INFO';
    For us to troubleshoot this for you you will need to disable the htaccess and reinstate the index.php as we don’t support he removal of it
    What’s in your channel entry tag for that single entry page? Specifically parameters
    Can you use a query string on a non Pages URL without issue?
  • #8 / Jan 17, 2011 1:45pm
    Fuel
    A quick test of using PATH_INFO vs. AUTO caused issues.
    I am currently removing all add-ons and will test and report back again after that.
    We use EngineHosting, if that info is valuable.
    With a fresh installation of 2.1.3, is this something that normally works without issue by default? I will find out soon enough, I just thought I would ask.
  • #9 / Jan 17, 2011 4:38pm
    Fuel
    I have now have a clean installation of 2.1.3 with zero add-ons and am having the same issue while the “uri_protocol” is set to “AUTO”
    Works: http://domain.com/index.php/test-page/
    404: http://domain.com/index.php/test-page/?test=123
    BUT, with the “uri_protocol” is set to “PATH_INFO” it is working correctly. So that means I have some testing to do with the add-ons that I generally use. My hunch is that NSM .htaccess generator is the culprit, but it’s a necessity so I will find a way to make it work regardless.
    I will do my homework on the “uri_protocol” config variable. That’s new to me. Any insight you can share would be helpful, as I prefer not to deviate from defaults unless it’s absolutely required.
    So, now the question is ... Since AUTO is the default setting, are there any known potential issues, hurdles or gotchas with using PATH_INFO? Again, we only use EngineHosting if that information is helpful.
  • #10 / Jan 18, 2011 7:58am
    Ordinarily you wouldn’t need to use PATH_INFO, but what this means is that instead of having index.php in your urls, you’d use index.php?. That’s the only potential gotcha.
    You’ll need to fiddle with your .htaccess on your own. We don’t provide direct support for removing index.php or index.php? using .htaccess.
    Does that help?
