I want to show my website to certain members
before I put it live, but I don’t want them to access
the control panel.
Is there a way to do this?
thanks
January 14, 2011 7:27am
Subscribe [3]#1 / Jan 14, 2011 7:27am
the control panel.
thanks
#2 / Jan 14, 2011 12:04pm
I’ll typically setup template access and do HTTP authentication.
#3 / Jan 14, 2011 12:04pm
Though, you would technically have to turn the system on for that to work. But if you lock down all your templates, that might not be a problem.
#4 / Jan 14, 2011 12:09pm
Thanks Joe,
Could you tell me how to do that?
May be an example?
#5 / Jan 14, 2011 12:14pm
Sure thing,
In the template manager, you will notice each template has an “Access” link. Click that and remove access to “Guests”. In the dropdown at the bottom, enable HTTP Authentication.
If you want to easily do this for several templates at a time, click the “Template Preference Manager” in the top right, which will allow you to set access to multiple templates at a time.
#6 / Jan 14, 2011 12:23pm
Great! I’ll give that a try, thank you.
#7 / Jan 14, 2011 12:23pm
No problem
#8 / Jan 14, 2011 6:04pm
Thanks for the assist, Joe.
inflicted, did that information help?
